Reply 20 of 40, by mr_bigmouth_502
- Oldbie
wrote:wrote:wrote:Define "Best" as it's very subjective what it means :) […]
Define "Best" as it's very subjective what it means 😀
My recommendation would be a Super Socket 7 or a good 486 system. They are more flexible in terms of running games that are speed sensitive and having grunt to play some of the newer ones.
With a 386 you are are "stuck" in a very specific time period and a Pentium 2 and higher isn't flexible when it comes to running speed sensitive games.
If I had to pick one it would be based on an ATX Super Socket 7 board because then you can use a new ATX case, ATX PSU and all of that.
So, how well do SS7 boards work with Pentiums? I know that they're intended more for K6/K6-2 CPUs, but the idea of being able to put a lower-end Pentium system into an ATX case sounds quite tempting.
There wouldn't be much point, though. The fastest Pentium you're going to get in there in most cases is a 233 MMX. You might get a 266 Tillamook running, but usually not without issues. Even with their relatively weaker FPU's, a fast K6-2 or III of 500mhz+ will still outperform a 233 MMX easily.
This isn't really an issue for me, as I'm not really looking to play any games made beyond the mid '90s on this hypothetical rig anyways. In fact, I'd actually prefer a somewhat slower system just to better handle older, more speed-sensitive games.
