Reply 20 of 25, by Mau1wurf1977
- l33t++
If the black levels are off you need to adjust the gamma setting. The 3DFX driver should have a setting for that.
I didn't even touch the gamma settings on my Voodoo2. I guess it's just set too high by default. All the colors look very dull.
Now, what could prevent the Voodoo3 3500 TV's TV out from working? I'm trying to hook up my Voodoo3 3500 TV to my TV via S-Video(Composite on a computer sucks, so I'd rather not use that), but no matter what I do, I cannot get the TV out to work.
Creator of The Many Sounds of:, a collection of various DOS games played using different sound cards.
I think 3dfx assumed everyone had junk CRTs that were too dim and upped the gamma by default. Voodoo1 is the same way.
Or maybe everybody at 3dfx was on a different gamma calibration standard.
wrote:I think 3dfx assumed everyone had junk CRTs that were too dim and upped the gamma by default. Voodoo1 is the same way.
I guess that depends on the model. I had Flash 3D voodoo 1 with an incredibly dark and warm (reddish) gamma settings. I remember that I needed to up the brightness and contrast of my screen back then to be able to see anything in quake 2 since gamma settings didnt really work with the out-of-the-box driver.
With diamond monster 2 and creative 3d blaster 2 i had no issues and the output was very nice.
BTW, composite output on V3 3500 should be pretty decent, why do think that it sux? 😕
I haven't personally seen the Composite coming out of the Voodoo3 3500 TV, but in general, when a graphics card has Composite on it, it looks so damn blurry you can hardly read small text. S-Video is a lot better for that.
If I can just figure out why the f*** my Voodoo3 3500 TV's TV out doesn't work. Anyone have any ideas?
I suggested 3500 TV for its DVI 😜
I've had TV out coming out of the 3000. Have you tried leaving in only the TV out before you start?
3dfx has some of the sharpest TV out i've seen on a video card BTW.
