Reply 20 of 21, by pjwulfman
@ bloodbat
Thats what I type into the DOS prompt, right? Pretty sure that's exactly what I did.
I do believe his copy is "cracked", so I don't know if that has anything to do with what happened.... It started out as just a disc Icon, and he told me I needed to extract everything with PowerIso. Then a ton of files and folders appeared. Not knowing what I needed, I created a new folder, put all of the files into the new folder, then "mounted" that folder into the DOS program. Nothing happened. Until everything fell apart.
Reply 21 of 21, by wd
Rank DOSBox Author
DOSBox Author
It is illegal to use unlicensed software. So better don't create more problems on that PC.
