Storage options on 486, feedback
Reply 20 of 61, by sunaiac
Ok, i lost my 29160 bid to someone else (volontarily)
I take a 2940U2W instead, seems safer on a 486, and it's not like i'll see much difference to run Doom.
I'll begin loking for the CD drive and Hard disk drive now.
R9 3900X/X470 Taichi/32GB 3600CL15/5700XT AE/Marantz PM7005
i7 980X/R9 290X/X-Fi titanium | FX-57/X1950XTX/Audigy 2ZS
Athlon 1000T Slot A/GeForce 3/AWE64G | K5 PR 200/ET6000/AWE32
Ppro 200 1M/Voodoo 3 2000/AWE 32 | iDX4 100/S3 864 VLB/SB16
Reply 21 of 61, by luckybob
Do an ebay search for "scsi plextor" Black drives from decommissioned servers are CHEAP, beige ones tend to sell for a good $10+ more than the blacks.
I run a 50 pin version of the plextor 40TSi in my 386 setup. In fact, its what I use to terminate the end of the cable. ^.^
Reply 22 of 61, by sunaiac
I'm amazed at SCSI drive prices.
Another of the things I dreamt of 20 years ago and costs the price of an entry to a movie nowadays ...
Might as well go full overkill and take a 146GB 😁
Only thing stopping me is the fact that 140 of them are never gonna be usefull, since even on my modern computer, a 80GB SSd is alrgely enough ^^
Reply 23 of 61, by Anonymous Coward
I second Plextor SCSI CD-ROM drives. I have an 8X tray loader in my XT, and a 32X caddy loader in my 486. Both of them are whisper silent. Very solidly built drives.
Reply 24 of 61, by nemesis
I personally like using IDE/CF adapters because of the blazing speeds, silence, and affordability. I wouldn't trust it for running Windows, though.
Reply 25 of 61, by sunaiac
Well I'm constantly teared between the fact I want the old school sensation, and the fact I want something pretty usable nowadays.
I'm sure CF adapters are really good. But I I go this way, i'll end up with a 133MHz Cyrix, 256MB ram, a SSD on a PCI sata controller ... And I'll end up very sad cause i'll have something that's definitively not a 486, but still an old crap compared to today standards.
Of course, I can't go the other way completely, cause if i rebuild the 486 I really had (200mb HDD, 4MB ram, SX33 ...), i'll start it once, see that doom will run 12FPS when i'm used now to 120fps, and i'll cry too ...
So, fighting hard to find the right balance, I think i'll stick to the SCSI system 😀
If really i can't take it, i'll put the 20€ in a CF system anyway 😀
Reply 26 of 61, by feipoa
sunaiac wrote:
Well I'm constantly teared between the fact I want the old school sensation, and the fact I want something pretty usable nowadays....if I go this way, i'll end up with a 133MHz Cyrix, 256MB ram, a SSD on a PCI sata controller ...
This system has my vote! Forget the DX4-100-WB, find an IBM 5x86c-100HF. I'm 1 for 2 at 133 MHz. A Promise SATA150 TX2plus is known to work well in PCI 486's. It contains both ATA and SATA ports.
sunaiac wrote:
Looking for a Intel DX4 100 Write Back (see avatar) CPU !
Between now and 3 months ago, I recall a few of these going for around $8 on CPU-world.com
Reply 27 of 61, by nemesis
feipoa wrote:
This system has my vote! Forget the DX4-100-WB, find an IBM 5x86c-100HF. I'm 1 for 2 at 133 MHz. A Promise SATA150 TX2plus is […]
I can back Feipoa up on the 133 MHz IBM 100HF chips. I'm 2 for 2 with one even running at 150MHz on certain motherboards. As for the TX2, it works like a charm.
Reply 28 of 61, by sunaiac
I'm on this one : http://www.ebay.fr/itm/300739190914?_trksid=p5197.c0.m619
If no one from here outbid me 😁
But I still want a DX4-100 WB Intel @ 120 ... I'd like to have the choice and try them all 😉
Reply 29 of 61, by feipoa
Sunaiac, that is an IBM 5x86C-100GB chip. I'm not sure how well it overclocks compared to the -100HF chips. Maybe just as good?
I think the G vs. H just implies no heatsink. The B vs. F might be the revision.
Reply 30 of 61, by sunaiac
Well I hope to be able to answer some time soon (that is within the next 3 month, given the speed at which i'm completing my project 😀 ), if I win the bid.
Reply 31 of 61, by sunaiac
I have a very stupid question, but i can't seem to find a clear answer.
I decided to go full SCSI on my 486s, and got myself several of those (same model, not at that price of course) : http://discountechnology.com/Seagate-ST318406 … CSI-Hard-Drives
I have adaptec cards, all in 50 pins, either 2940 PCI for the PCI 486 or 2842A VLB for the ... well VLB one.
I obviously have no troubles with the speed limitation at 20mb/s, but i'm puzzled about that LVD stuff.
It seems it should work with a lvd certified adapter. Could anyone point me an ebay listing with an adapter that is sure to work ? I have 68 and 50 pins wires, but since I also got the CD burners to plug, i'd prefer a HDD side adapter.
Thanks !
edit : there's a "Force Single Ended" jumper on the HDD if it can help.
Reply 32 of 61, by luckybob
Its all about termination. The Achilles heel of scsi. Some 68 pin scsi hard drives do NOT like being on 50 pin cables. I have such a drive in my collection like this.
I would use a regular 50 pin cable, have a 50>68 adapter on the hard drive, followed by any other drives you have. Try to keep everything 50-pin.
Reply 33 of 61, by sunaiac
Well the circuit would be simple : Adaptec --> HDD with 68pins adapter (the one i need to find) --> CDROM with termination on, all on 50 pin wire.
some sellers do tell about termination (http://discountechnology.com/68pin-50pin-SCSI … yte-Termination) but i'd like to find the same thing cheap on ebay, where they sadly don't tell about termination...
Reply 34 of 61, by luckybob
if the hard-drive has an internal 68 to 50 pin termination (most do) then there should not be any problems with that. the terminator you linked, would be necessary only if the drive does NOT have that form of internal termination.
Reply 35 of 61, by carlostex
I use an IDE to SD adapter. Using a microSD 512MB card works great with my 486 system. Disk access times are much much faster than any of my old hard drives with less than 2GB. Transfer speeds seems to be fast enough. And there is virtually no noise. I won't be using hard drives again.
Reply 36 of 61, by sunaiac
Ok, i'll get the 3$ adapters then, and hope for the best. Worst case i fall back on the expensive ones.
Thx.
Reply 37 of 61, by sunaiac
Well 3$ ones are the female ones ...
Of course male ones are 17€, but are equipped for termination.
So, too bad, i'll pay adapters ore than disks themselves ...
That's what I'll do if I fail miserably with my SCSI setup 😁
Reply 39 of 61, by sunaiac
I found 18 GB 10k seagate HDD with 68 pins for peanuts, so that's what I have 😁
I'll do a progress report, just ordered some adapters 😀
