ISA or PCI sound card?
Reply 20 of 48, by TheMAN
that vortex2 card with the colored jacks looks just like my dynex card with a via envy24 chip, except the card is pink... that's the most modern card I have 🤣
they still have drivers for the envy24 that works with a modern OS, what about the vortex2?
Reply 21 of 48, by Tetrium
Mau1wurf1977 wrote:
Tetrium check these out: […]
https://plus.google.com/photos/10811747109024 … =CPKIpone-7W2UA
I have 2 Vortex 2 cards. I got a Turtle beach a while ago, but recently purchased this new Techworks Vortex2 SuperQuad. Haven't played with it yet, but it comes with a driver disc.
The drivers for the Turtle beach can still be downloaded from their website 😀
Both cards have a wavetable connector, so the NEC XR385 is a perfect match. Allows you to play many of the newer DOS games with fantastic General MIDI music. E.g. Doom, Descent, games like that.
Yes, I downloaded what I believe are all their Vortex and Vortex 2 drivers, but they are all named "Montego II" or "Montego II Plus" and such, but the cards themselves have model numbers "ASC338" and "ASC338(E)" and I couldn't figure out which Montego belonged to which ASC338 card 😵
So I guess I'll just have to either read the documents that came with the drivers (all 5 Montego cards look very similar) or I'll have to guess 😵
I have maybe 1 or 2 daughterboards, and they are nothing special I think. One has "Dream"-something on the main chip and the other I can't remember (but it was quite a small daughterboard). I never really invested any money into my sound card collection, I basically make due with what I found/got for free 😁
I don't know. I believe Turtle Beach don't have drivers for their Vortex (2)cards for Windows 7 and such, but since all my Vortex cards are either Turtle Beach and Aztech, I didn't bother to look any further. All my cards are Vortex 1 with just 1 Vortex 2 in the pack.
My retro rigs (old topic)
Report spammers here!
Reply 23 of 48, by gerwin
The Montego (A3Dxstream) is the Vortex 1 based card, The Montego II is vortex 2 based. They look very similar. Both cards were also sold by Dell.
The additional Montego II editions differ in add-on modules: I have one digital I/O add-on module which can be connected with a ribbon cable to the Montego II base card. The base card can work with generic Vortex Drivers, but add-on modules require one to use the Turtle Beach supplied driver.
Reply 24 of 48, by sliderider
Does anyone have a TB Montego II Quadzilla? i read about them, but never saw one for sale.
Reply 26 of 48, by Tetrium
I may have one (I have 2 of those Turtle Beach sound cards here), but I don't know which cards they are, only that 1 of them is a Vortex with part number ASC338 and the other has part number ASC338(E) and is a Vortex 2. There were 5 Montego's on the Turtle Beach website and I don't know which name represents which part number! 😵
swaaye wrote:
BTW, with Vortex 2, use driver 2041 because 2048 has a lot of bugs like reversed sound in some games.
A glorious FTP archive
ftp://ftp.nchu.edu.tw/Hardware/multimedia/Aureal/
Thanks a lot for this link, Swaaye!
Thanks for this info Gerwin! I assumed the Turtle Beach required the Turtle Beach drivers for some reason.
Swaaye pointed me to some generic Vortex drivers which I'm downloading right now 😁
Reply 27 of 48, by DataPro
Hello,
I got a HP Vectra Pentium 166Mhz/L2 256ko cache / 3 PCI slots + 2 Isa slots
I've put a SoundBlaster128 PCI and a SoundBlaster AWE64 ISA PNP (CT4500) inside.
The OS is Win98SE.
The 2 soundcards are working well under Win98SE; I can have PCM sound from SB128 and MIDI sound from AWE64 at the same time.
Under DOS, when I try to play DOOM, I can't hear any sound.
I use CTCM to get SET BLASTER parameters. I use the same parameters in autoexec.bat and in Doom's setup... nothing happens.
I also have a Roland MT-32 and I project to connect it on the AWE64 for playing DOS Games and listen Midi under Win98SE.
CONFIG.SYS :
DEVICE=C:\WINDOWS\HIMEM.SYS
DEVICE=C:\WINDOWS\EMM386.EXE NOEMS I=B000-B7FXX
DOS=HIGH,UMB
DEVICE=C:\WINDOWS\setver.exe
device=C:\WINDOWS\COMMAND\display.sys con=(ega,,1)
Country=033,850,C:\WINDOWS\COMMAND\country.sys
DEVICE=C:\DOS\AWE64\CTCM.EXE
AUTOEXEC.BAT
prompt $p$g
C:\DOS\AWE64\AWEUTIL.COM /S
SET BLASTER=A220 I7 D1 H7 P300 E620 T6
SET SOUND=C:\DOS\AWE64
 Répertoire de C:\DOS\AWE64
14/10/2014 07:25 <REP> .
14/10/2014 07:25 <REP> ..
13/01/1997 01:00 22 958 AWE64FAQ.TXT
11/06/1997 01:36 28 260 AWEUTIL.COM
26/10/1995 01:01 6 402 AWEUTIL.TXT
21/10/1996 04:05 295 074 DIAGNOSE.EXE
12/06/1997 02:17 106 422 MIXERSET.EXE
18/08/1995 01:22 18 008 CTMIDI-S.DRV
07/04/1995 01:14 9 919 CSP.SYS
12/02/1997 02:02 18 090 CT3DSE.EXE
06/06/1996 01:23 65 230 CTMIDI-A.DRV
12/06/1997 02:17 389 CTMIX.CFG
03/05/1995 01:03 10 330 CTMMSYS.SYS
16/05/1996 03:02 33 865 CTSB16.SYS
09/09/1994 04:04 15 586 CTWDSK.DRV
29/07/1994 01:03 31 372 PLAY.EXE
30/07/1994 01:03 19 426 RECORD.EXE
15/07/1997 01:09 593 631 CTCU.EXE
14/04/1997 01:08 87 508 CTCM.EXE
14/04/1997 01:08 428 CTPNP.CFG
14/10/2014 07:25 <REP> DRV
19 fichier(s) 1 362 898 octets
Répertoire de C:\DOS\AWE64\DRV
11/07/1997 04:16 5 898 AUXDRV.DRV
14/10/1994 04:05 31 842 CT-VOICE.DRV
06/06/1996 01:23 65 230 CTMIDI.DRV
20/02/1997 03:04 34 353 CTSB16.SYS
09/01/1995 04:08 45 954 CTVDSK.DRV
07/12/1995 04:04 12 218 CTWMEM.DRV
Any idea of what's wrong ?
Thanks for help!
HP Vectra 562 P166Mhz/256Ko L2 cache/Triton 430FX - 112Mo RAM - 2x 32Go+64Go CF Card - Matrox G2 8Mo - SB AWE64 ISA (PnP) + Roland MT-32 & M-GS64 (SC-88) & JV-1010 - Nec USB 2.0 PCI - Promise Ultra100 TX2 - Hama multicard reader
Reply 28 of 48, by Sammy
how do you connect the soundcards to the Speakers?
Do you connect lineout from soundcard1 to Linein from Soundcard2 and then from SoundCard2 to the Speakers?
Then Check mixersettings in Dos maybe Midi oder Linein is Muted.
And i can't See any DOS Drivers loaded for you PCI Soundcard.
Can you try Doom inside the win98 command prompt?
Reply 29 of 48, by DataPro
The SB128PCI out is connected on AWE64 line in and speaker on AWE64 line out.
But I tried also with speaker connected to SB128PCI with Doom playing. No sound either.
You're right, I only tried to make AWE64 working under DOS; so I haven't tried SB128PCI DOS Drivers.
Do you think it's possible to make both soundcard working together under DOS ?
When I will connect my Roland MT-32, which card will I choose ?
Reply 30 of 48, by PhilsComputerLab
Start working with one card at a time. Two Creative cards can be challenging. Personally I would just use the AWE64 Gold 😀
It is also the perfect host card for the Roland MT-32, in combination with SoftMPU project (more info in the SoftMPU thread).
YouTube, Facebook, Website
Reply 31 of 48, by DataPro
Thanks phil,
That's my opinion. The SB AWE64 seems to be good alone for DOS gaming and MT-32 support.
Now I have to work more on my configuration files...
After receiving my MT-32 last week, I will have a Matrox Mystique 220 PCI tomorrow. So I need to make sound work tonight.
Any help will be greatly appreciated.
Reply 32 of 48, by PhilsComputerLab
Try with games like Monkey Island if the MT-32 works. Use joystick MIDI cable MIDI out to MIDI in Roiand.
Reply 33 of 48, by carlostex
I would say it's doable. Not only i use a SB Pro 2 and an AWE64 but i have a GUS in there as well. Works well.
Reply 34 of 48, by DataPro
phil, I will receive my Joystick/Midi Cable next week. At this time, I use the Roland MT-32 on my Atari ST.
carlostex, how are your config.sys and autoexec.bat ?
Reply 35 of 48, by DataPro
I crashed Win98SE by installing DOS drivers for AWE64 because it has also installed Win3.11 drivers in Win98 system's directory...
I restored Win98SE and I installed SBPCI128 DOS drivers.
Now I have SB128PCI running under DOS and WIndows98SE but I've lost Win98SE AWE64 support !?
I think I need to manually installed DOS AWE64 drivers.
Reply 36 of 48, by chinny22
What I did to get around the drivers checking what version of dos is installed, installing crap in Windows, etc is to install the drivers in Dos first. Copy that folder usually SB16 and the autoexec and config.sys files somewhere else. Do a clean install of Win9x. including sound card drivers, then copy the files back. Dos drivers don't care what OS you are running just the installer and don't need to know anything about windows.
Reply 37 of 48, by sliderider
In a 486 PCI motherboard or a slow Pentium motherboard, you're probably better off to use an ISA sound card. You don't want to overload the PCI bus in a slow machine with too many devices.
Oh, since my last post to this thread I have gotten a Quadzilla. 😁
Or was it two Quadzillas? I forget now. 😒
Reply 38 of 48, by 2fort5r
DataPro wrote:
I crashed Win98SE by installing DOS drivers for AWE64 because it has also installed Win3.11 drivers in Win98 system's directory. […]
I had a similar problem recently. I was testing a real DOS 7.10 environment but the installer insisted that I was running Windows and I wound up with a corrupted driver installation that wouldn't work properly. Use of SETVER fixed some of the issues but I still wasn't getting proper sound and gave up in frustration. Back to 6.22.
Account retired. Now posting as Errius.
Reply 39 of 48, by PhilsComputerLab
This happens if you are using the MS-DOS drivers! There are separate drivers for Windows 95 MS-DOS mode. While they don't come with an installer, they will work 100%.
I've added it to my list of videos I would like to re-do because this question / problem pops up all the time 😀
