Mcdex not noticing new cd-rom
Reply 20 of 23, by keropi
Hmmm... I use a cd-rom driver that only states this:
IDE/ATAPI CD-ROM Device Driver Version 2.11 17:30:39 06/07/96
and it consumes 5.072 bytes of memory, upper or conventional... never had any probs with it and I couple it with MSCDEX for compatibility reasons ...
edit: had a look at the .exe, it's from ACER 😁 you guys should check it out, it never failed me, the only problems that I encountered ever was with software (like Fade To Black - no videos) that need the original mscdex to function properly...
edit 2: updated 2.15 version at mdgx's site: download the VIDE-CDD.SYS package, it has both 2.14 and 2.15 versions with support files
Reply 21 of 23, by RoyBatty
If the drive plays audio cd's the laser is not dead at all...
Reply 22 of 23, by swaaye
MSCDEX and the device driver are separate entities. 😀
MSCDEX is definitely the safest bet compared to say SHSUCDX because DOS games tended to be tested and written specifically for MSCDEX behavior.
Reply 23 of 23, by dosquest
Roy, it dos not read any type of cd, I was saying the audio pass through (the audio out hack on the front of the cd rom drive, when hooked up using the audio cable to the SB pro card, it channels the sound from the audio card when playing either a native sound file or a file from a floppy
Doom isn't just a game, it's an apocalypse survival simulator.
