Reply 20 of 45, by AlucarD86
- Member
yes I will 😁 I am so glad that I was even able to get it to run 😁 as for the controls they are very easy once you get used to them (get a gamepad like the gravis gamepad one), RE 1-3 have the same tank controls and even Code Veronica does I think, hell in RE4-5 you are still forced to stand still while shooting 🤣 this was only a test run as I still need a case, soundcard and capture card to actually capture some of this but so far wow yeah the higher resolution and better shadows are superior to the direct 3D I would say.
PC Setup: Mainboard ASUS CUBX | CPU Intel Pentium III-S Tualatin 1.4 GHz | Memory 780 MB SDRam | Soundcard Creative SB Audigy SB0160 | GPUs Nvidia FX5900 Ulta Matrox M3D PCI | HDD 2x40 GB WD/Seagate | OS Win98SE and WinXPSP1 in dual boot
