Reply 20 of 65, by carlostex
- l33t
wrote:I rediscovered the menu I used back in the day and I'm loving it. It's called Power Menu, and it is quite powerful. Lots of conf […]
I rediscovered the menu I used back in the day and I'm loving it. It's called Power Menu, and it is quite powerful. Lots of config options and only takes up about 3K of memory. It's great to have easy access to all of the stuff on my HDD - here I was using the command line like neanderthal man.
It can be found here under the link "Power Menu 4.11": http://toastytech.com/guis/indexlinks.html
Does it stay resident in memory when you start the games and programs?
