Reply 20 of 24, by Kahenraz
- l33t
wrote:If you are interested in learning C++, you need to be aware that C++ has been evolving ever since Bjarne Stroustrup first released it in the late 1970s. A Borland compiler that supports DOS won't implement the more recent developments in the language and any C++ books written when your Borland compiler was current will also be comparatively out-of-date.
akula65 is right. You're going to have to make sure you get a book dated to match the compiler you're using. Or if you're using an old compiler like Borland, try to get a book written for it specifically.
