Voodoo (and Voodoo 2) issues on Pentium 4
Reply 20 of 26, by Jade Falcon
Rank BANNED
BANNED
Or use a dx supported driver. But guess what! They're buggy as hell.
http://www.3dfxzone.it/enboard/topic.asp?TOPIC_ID=1514
I personally prefer kool smokys drivers. But fast voodoo is ok too, just older.
Reply 21 of 26, by dr.zeissler
Thx. I was not sure about this, but I only want glide, D3D is just fine with the NV6200, but I get no glide at all.
Reply 22 of 26, by Gamecollector
Well, steps for P4 + Voodoo2 SLI + WinXpSp3 in my case:
1) Install Voodoo2 W2k 1.02.00 drivers through Device Manager (update driver, have disc, voodoo2.inf etc). Twice.
2) Change the startup type for 3 Voodoo2 services (fxgpio, fxcpl, ntremap) to "System". Device Manager, "show hidden devices", "non-PnP devices drivers", "Voodoo2 PCI I/O" | "Voodoo2 Memory Mapper" | "Voodoo2 Board Remapper". Or HKLM\ Control\ CurrentControlSet\ Services\ ...\ Start="1".
Another way is to edit Voodoo2.inf itself.
So - you have glide and ogl (not added to HKLM\Software\WindowsNT\OpenGLDrivers so only limited number of games will use it).
If you get the "... expected Voodoo^2, none detected" message then your Voodoo2 is faulty. It can be fixed with "remove / insert thes Voodoo2 from / to the PCI slot" but this is the temporaly solution...
P.S. The same method have worked with C2D E8400 / Q45 Express...
Reply 23 of 26, by dr.zeissler
I used only one Voodoo2 and it WORKS! Don't know why, every driver seems to work properly.
I think it's a SLI problem, or one of my (identical) Voodoo2's are broken; I will test this today.
Reply 24 of 26, by Jade Falcon
Rank BANNED
BANNED
Test both cards by them selves. if both cards work alone then maybe its the SLI cable or a device conflict.
Reply 25 of 26, by dr.zeissler
One card does not get warm, it's defect. I can't determine what the Problem with this Voodoo2-Card is.
Reply 26 of 26, by dr.zeissler
I use the other Voodoo2 instead and it works perfect in theis system. Thx.
