Turtle Beach Tahiti any good?
Reply 20 of 31, by vmunix
Stojke wrote:
But NEC X385 works on plenty of ISA cards. I could place it upside down, but thats just silly.
Thanks for the reply, i guess i will just listen some CD audio than 😀
I know, the problem is sometimes although they are electrically compatible, physically they are not you can't place the card back into the ISA slot, and viceversa.
The Rio synth that came with the Monterey was physically very similar to the WaveBlaster CT1900 and they are electrically compatible, so don't trow the towel yet.
Trailing edge computing.
Reply 21 of 31, by Artex
I installed my Monterey (Tahiti+Rio) in my Socket 3-based system last night. Got everything working in Windows 3.11 after about 45 minutes of trying to figure out why the MIDI portion wasn't working (no output). Definitely sounds great compared to the noisier SB cards I'm used to. Too bad this card/combo cannot be used for some of the more popular DOS games like DOOM, Duke3D, or other games with general midi music. It would be nice if there was a way to change the MIDI port.
Reply 22 of 31, by vmunix
I haven't tried it yet, but a driver to use the standard MPU-401 midi interface from DOS exists and it's available on Turtle Beach ftp site, I know it is used to run Cakewalk and other DOS based sequencers, so it should work also with any DOS application. I will try it when I have time, first I need to assemble a dedicated PC for this and other tests I have in mind.
Theoretically with the driver you could use this card in the same way as the Roland LAPC-I coupled with any SB pro to get digital effects and great MIDI music
Rio has 4Mb sample set uncompressed in 4Mb ROM so it's pretty good.
EDit: follow these instructions:
http://support.turtlebeach.com/entry/59036839/
Reply 23 of 31, by Stojke
When i try to play CD Audio i get no output. I check the line levels and nothing is muted. The CD Audio Player shows that its playing and CD Drive indicates that its busy.
The CD Drive is NEC CDR-501.
Reply 24 of 31, by vmunix
Of course you have the internal analog cable connected right ?
Also take a look at this.
http://support.turtlebeach.com/entry/590411830/
Reply 25 of 31, by Artex
vmunix wrote:
I haven't tried it yet, but a driver to use the standard MPU-401 midi interface from DOS exists and it's available on Turtle Bea […]
Yeah, Bristlehog mentioned that as well. I wonder if that utility lets you redirect the MPU-401 from the Windows Shell session to a specific port - like 330, for DOS games that use GM soundtracks. I may try it this weekend and see how far I get. All I really want is to hear those sweet, sweet GM DOOM tunes from the Rio daughterboard. 😎
Reply 26 of 31, by Stojke
Oh yeah, the cable 🤣
Which one of the two headers should I connect it to?
Reply 27 of 31, by Stojke
I was a bit dissapointed to find out it doesn't digitally input the signal from the CD, but over analogue connection. My CD player already has kick ass analogue shit in it, so I burned WAV files onto a disk (with various music types and instruments) and I was amazed at how GOOD does this sound card sound.
There is no better sounding ISA sound card than the Turtle Beach Tahiti and Pinnacle that I have heard. Creative cards are crap compared to these, and AWE64 is a joke.
I still want to hear that rare CardD one.
Reply 28 of 31, by vmunix
Now you see it, many independent and commercial publications still have the Multisound series as benchmarks, particularly the Tahiti/Fiji.
In 1996 my room mate had a Monterey and when I listened to it and compared to my better than average Diamond sound card I went the other day to buy a Turtle Beach.
The card you have shines while recording, if you plug an electric guitar, keyboard or any instrument or even a turn table to record from vinyl.
Unfortunately the card doesn't like much DOS gaming, someone posted a list of compatible games, although if the game runs under Windows will certainly works, I haven't tried Scummvm yet but I suspect it'll work too.
Go to page 167
https://books.google.com.ar/books?id=eMKimy4D … epage&q&f=false
Reply 29 of 31, by bristlehog
I posted a small list of Tahiti-compatible games at the previous page of this topic.
Making Tahiti and Fiji/Pinnacle compatible game drivers is on my todo list, but not before I finish Innovation SID player.
Here you can get fantastic wallpapers created by a friend of mine: patreon.com/Unpocodrillo
Reply 30 of 31, by QBiN
I imagine you could use an IDC ribbon cable to extend the waveblaster connector away from the board to overcome the physical dimensions.
Reply 31 of 31, by Stiletto
This all sounds awesome 😀
do the Fandango!" - Queen
Stiletto
