Reply 20 of 22, by 919guy
I have such a board and would like to use it for a 6x86 project.
Is there a pinout for the PS/2 port? There is nothing specific in the manual.
Asus used a 8 pin header on many Pentium and Pentium Pro boards all with same pinout. Check the P/I-P55TP4N manual 2.0 on TRW, page 19.
https://theretroweb.com/motherboard/manual/p5 … f4005672727.pdf
To verify use a voltmeter to check +5v on pin4 and measure the Ohms on the ground on pin1 to a black PSU lead.
Horun wrote on 2024-10-12, 20:22:Asus used a 8 pin header on many Pentium and Pentium Pro boards all with same pinout. Check the P/I-P55TP4N manual 2.0 on TRW, page 19.
That should help. Thanks! 😀
