Reply 20 of 36, by King_Corduroy
I have the same problem. I have a Yamaha XG PCI card and I can't get it to work in DOS for the life of me. 🤣
Check me out at Transcendental Airwaves on Youtube! Fast-food sucks!
Reply 21 of 36, by Jorpho
Davros wrote:
but does that display the autoexec.bat for dos or the autoexec.bat for dos mode in windows ?
Unless you install Windows 9x over MS-DOS 6.22, there is only one autoexec.bat. (There is a dosstart.bat that is run if you "restart in MS-DOS mode" from within Windows.)
Reply 23 of 36, by Davros
well then looks like your autoexec.bat is empty
thats why you have no sound in dos you need the enviroment variables for your card (aka the set blaster lines)
Reply 24 of 36, by Davros
is there a program he could run to detect the irq/dma his card uses
ps: are there jumpers on the card and do you have the manual
the yamaha is hardware compatible with a sbpro without any drivers
appears to default to irq 5 dma 1
try adding this to your autoexec.bat
SET BLASTER=A220 I5 D1 T4 P330
Reply 26 of 36, by Jorpho
There's the SETBLAST.EXE utility discussed at Sound Blaster types . I have attached a copy from the shareware episode of Blake Stone available at http://www.classicdosgames.com/game/Blake_Sto … ns_of_Gold.html .
Even on a laptop?
    SETBLAST.EXE
    74.95 KiB
    1057 downloads
Reply 27 of 36, by filipetolhuizen
Looks like autoexec.bat is empty. You'll have to see if there's a SB emulator for your card (most cards of that era have one).
Reply 30 of 36, by Kanade
ok i ahve tryd and those drives works. i ahve get sound now in DOS^^ thx so mutch for the help^^.
and i gat one more questing. anyone know how to get higher ress in dos? cuz i have like a box and black borders anyone know how to remove those borders that i have?
Reply 31 of 36, by leileilol
Depends on what video chip's in there and if it supports stretching (often found in the BIOS as an option, sometimes found in the video card's properties in windows, as well as sometimes in some OEM's configuration programs). You will want to probably play at your native res (1024x768), or native res / 2 (512x384) for best results with fitting
long live PCem
Reply 32 of 36, by filipetolhuizen
Some widescreen monitors have a setting that makes the image fill the whole screen. The picture will look horribly stretched as DOS games use 4:3 resolutions.
