Pentium 4 or Celeron D?
Reply 20 of 48, by Gamecollector
IIRC Northwood A - 400 MHz FSB (up to 2 GHz, to distinguish from Willamettes), Northwood B - 533 MHz FSB, Northwood C - 800 MHz FSB.
Prescott A - 533 MHz FSB (they not intersect with Northwoods A, because the lowest Precott A speed is 2.26 GHz), Prescott E - 800 MHz FSB.
As the example there are 2.8, 2.8B, 2.8C, 2.8A, 2.8E variants for the 2800 MHz version (Northwood 400/533/800, Prescott 533/800).
LGA 775 versions use processor number.
Maybe your CPU is P4 2.4B and motherboard is ok?
Reply 21 of 48, by PcBytes
Gamecollector wrote:
IIRC Northwood A - 400 MHz FSB (up to 2 GHz, to distinguish from Willamettes), Northwood B - 533 MHz FSB, Northwood C - 800 MHz […]
I'm very sure it isn't because the CPU says i's a SL66Q,which CPU World says it's a P4 1.8A.
Also,has anyone heard of SNDS? (Sudden Northwood Death Syndrome)
Reply 22 of 48, by JaNoZ
SNDS is when you apply a small amount of vcpu in addition to stock voltage and the cpu melts its wires inside like they were fuses of some sort.
Ending up a dead cpu. if i am right. cooling not even mentioned.
Reply 23 of 48, by PcBytes
Spooky stuff.
SL66Q Northwood 1.8A's default voltage is (almost)1.6v,I shouldn't exceed 1.75v (SNDS starts at 1.75v)
Also,I found out why my 1.8A is running at 2.40GHz.It's because the BIOS automatically sets the FSB at 133x18,so the FSB would be 533 at this point because it's using QDR.(Quad Data Rate)
Reply 24 of 48, by obobskivich
Is the board setting you to 133FSB because a divider is either not being set, or is being improperly set?
Reply 25 of 48, by PcBytes
I have no idea at this point.
Maybe it's seeing it as a 133FSB CPU? (like the Celeron D)
Reply 26 of 48, by JaNoZ
This board is able to do 800fsb right?
Why not put in a 800fsb cpu?
Reply 27 of 48, by PcBytes
Because the only place that sells Socket 478 CPUs,it sells them at a ridiculous high,despite all being second hand.Also I plan on getting a original Xbox.
I'd better stick with my CPUs,at least they're free.
Reply 28 of 48, by JaNoZ
I thought you can pick them up from ebay for a few euro's.
Reply 29 of 48, by obobskivich
Yeah it shouldn't be terribly expensive, like this guy:
http://www.ebay.com/itm/281388940257 😀 (it says worldwide shipping)
Still not free though, so there's that. 😊
Reply 30 of 48, by PcBytes
Rather than use a HT Preshott,I'd stick with a HT Northwood 🤣
Reply 31 of 48, by PcBytes
Alright,here's the CPU-Z validation of my Northwood:
http://valid.x86.fr/8c2fe0
Reply 32 of 48, by Gamecollector
Interesting. AFAIK default FSB is hardcoded in the CPU and can be readed by CPU_ID instructions. There are motherboards with a bugged CPU_ID support?
Reply 33 of 48, by PcBytes
Possible.
Motherboard is incorrectly detected as Unknown Springdale-G. It's actually a 865G adapted Iwill P4SE-Gold BIOS.
And the noname stick is actually a V-Data 256MB stick.
Also,the temperature is funny : -1*C! 🤣
Reply 34 of 48, by ODwilly
My in-progress Prescott system tells me to contact HP to update the cpu microcode when it starts up and that the cpu is unknown. Yet the bios detects it as a Intel Pentium 4 670, which it is. Seems to work good so far, if it runs stable and does not give you any problems who cares right?
Reply 35 of 48, by PcBytes
"If it ain't broke,don't fix it!"
Reply 36 of 48, by ODwilly
In typical HP fashion they decided that the xw4400 was designed for a narrow range of Core2duo chips and did not see fit to upgrade the Bios to allow newer Core2's or any Pentium 4 chips 😒 lots of support threads angry at a lack of core2quad microcode updates and reports of 100% stability ignoring the notice and using them anyways!
Reply 37 of 48, by PcBytes
If I'd were you,I would have changed the motherboard with a usual one.
HP puts on their motherboards a crippled BIOS of the board,not to mention they cripple the board too. (like the P4SD,which is actually the P4G800)
Nowadays a LGA775 motherboard shouldn't be too expensive,at least not the older ones like i945,P35 and such.
Reply 38 of 48, by Stiletto
I have seen (once or twice) people BIOS modding to add more modern CPU microcode into the BIOS, perhaps this can be investigated. Of course it would all be unofficial, etc.
do the Fandango!" - Queen
Stiletto
Reply 39 of 48, by PcBytes
When it's about a OEM board,it just isn't worth it,since most OEMs write protect the BIOS.
He needs a new LGA775 board for the CPU to work(Pentium 4 CPUs won't work on this one),and IMHO this one is the best replacement to what he has,and with both types of RAM:
http://www.ebay.com/itm/Foxconn-X38A-Motherbo … =item3f3ac3284a
and another one for Pentium 4 chips:
http://www.gigabyte.com/support-downloads/cpu … p.aspx?pid=2847
