Reply 21 of 43, by DracoNihil
The pentium logo showed up for me if I set cputype=pentium in Daum. If you examine DARK.EXE in a hex editor you'll find a "GenuineIntel" string. I don't know how the game really detects a Pentium processor, it might be trying to detect a very specific model.
And what do you need to do to test what I said? Just jump around, find a pirate shuttle, take out it's escort and fly over to the blind spot of the shuttle. Switch to rear view mode and fire your weapon. If the speed issue is not a DosBOX emulation bug then your target should be dead within seconds. You should also hear a flood of laser and shield hit sound effects and possibly the "Guns overheating" warning numerous times in a row.
― Κυνικός Δράκων
Reply 22 of 43, by Mau1wurf1977
🤣 I couldn't even fly straight with the mouse. I don't think I will be able to test this. Not much of a gamer you see 😊
The game was quite slow though. The MMX 166 certainly struggling a bit to keep the frame rate high.
My YouTube channel
Reply 23 of 43, by DracoNihil
That spells doom for me, I wonder if Privateer 2 would perform better on a Pentium 2 or a Pentium 3? Would the SVGA card also be a bottleneck?
― Κυνικός Δράκων
Reply 24 of 43, by leileilol
HINT: Privateer 2 came out when the Pentium 200 (not MMX) was the cream of the crop. The results of it being slow might be either a specific problem or some shock that it's not a 60fps SVGA game (which didn't really exist in 1996 for most Pentium people anyway)
long live PCem
Reply 25 of 43, by Gramcon
Indeed, the deluxe version (and that's running under Windows 95, mind you) lists Pentium 90 and 16MB RAM required, Pentium 166 and 32MB recommended.
I will download from GOG and try on my Pentium 166 non-MMX and let you know how it goes....
Reply 27 of 43, by DracoNihil
This games engine seems heavily unoptimized... Why the hell does getting too close to any texture mapped object (especially the planets) cause such a massive slowdown? I don't even get that problem in Quake even when Quake runs in DosBOX.
― Κυνικός Δράκων
Reply 28 of 43, by leileilol
Not every company can afford Abrash.
long live PCem
Reply 29 of 43, by archsan
This company could afford Christopher Walken and Clive Owen though. 😁
"Any sufficiently advanced technology is indistinguishable from magic."—Arthur C. Clarke
"No way. Installing the drivers on these things always gives me a headache."—Guybrush Threepwood (on cutting-edge voodoo technology)
Reply 30 of 43, by Gramcon
OK, here's some updates. I was able to get the GOG version to play in real DOS, well, actually, FreeDOS, but same difference. Thanks Mau1wurf1977 for the cfg file settings. Here's some observations, and this is on a 166MHz Pentium non-MMX with 128 RAM.
1) Yes, video cutscenes have scanlines and are dated. But that's how I remember it. That was the quality of FMV in computer games back in '96.
2) Everything played....really smooth. No problems. Now, before I calibrated my joystick, the sound was stuttering and everything was goofing up. After calibration, and setting controls to joystick (it seemed to default to mouse, really?) it played great. I just did some quick jumping around and dogfighting with maybe 3-4 other ships on the screen, no skipping, lag, etc. I'll play more later and see if this changes with incredibly large battles, but I doubt it. This is the recommended system configuration (actually, much more RAM than necessary!) for this game.
Reply 32 of 43, by DracoNihil
Get yourself into a massive Kindred ambush, (spoilers) like the one when you have to escort Hugo to Hephestaus. That slowed DosBOX to a crawl.
And I remember lack of joystick affecting Privateer 1, but I have a joystick being emulated in Daum but not assigned in the keymapper.
― Κυνικός Δράκων
Reply 33 of 43, by Gramcon
I tested without the joystick, and it ran smoothly (albeit I cannot control the ship with the mouse very well). I think the reason it was wonky the first time was that I hadn't calibrated the joystick (even though the joystick was not selected). Press ALT-O in flight to access the options, calibrate, and see if that changes things...
Not sure why else you would be having trouble. I have a P166MMX coming in the mail soon to replace my P166. I'll install it and see if that makes a difference. Maybe it's a weird bug where it doesn't like MMX chips, though I've never known that to happen with anything anywhere.
Gotta love the Intel Inside logo and sound that pops up when you start. Classic.
Reply 35 of 43, by leileilol
again, 1996 games on 1996 computers can't expect 60fps smooth SVGA software-rendered games. It wasn't until 3dfx accelerators and later Pentium II that 60fps 640x480 became commonplace
long live PCem
Reply 36 of 43, by archsan
Mau1wurf1977 wrote:
Doubt it's the CPU. But then it could also be a subjective thing. Is it 60 fps smooth?
Don't expect that kind of consistency on P166. P2 or P3 may be smoother though. As leilei said, your eyes got spoiled by the Voodoo(2)s. 😉
Reply 38 of 43, by DracoNihil
Mouse control in this game is a hell of alot better than Privateer 1, but of course I'm playing in Daum not a real system...
― Κυνικός Δράκων
Reply 39 of 43, by Mau1wurf1977
I must reverse my mouse control.
Tried it on the Pentium III. Firstly the game doesn't run without sound. So I used a AudioPCI. All good.
Game seems to be speed sensitive, like everything from Origin 😀
Like the mouse cursor just spins super fast. Menus open fast. The game also seems too fast. But smoother and with tearing so I guess it reaches a fps > 60.
My YouTube channel
