1gb SDRam detected as 384mb?
Reply 20 of 21, by JayCeeBee64
Rank Retired
Retired
borgie83 wrote:
unfortunately it's starting to play funny buggers with me again. First boot recognises 512mb, 2nd boot 384mb and then back again. Just depends on how she's feeling at the time. Have just put in an eBay offer for some new Micron double sided ram so hopefully the seller accepts it so I can get the ball rolling again.
See if you can try what I suggested in an earlier post first borgie83, take the double sided ram from one of your other BX440 builds and install it in the Gigabyte board; hopefully it will behave itself with the right kind of ram.
Question; why does this 133mhz ram which is CL2 recognise as CL3? Bios limitation or is it because of the issue with single sided ram?
Most likely the ram issue (it detects incompatible ram and defaults to safe settings), but it could also be the Bios - or both.
Ooohh, the pain......
Reply 21 of 21, by cdoublejj
unless the ram has really funky issue which is possible it should be detect the same amount each time consistently.
