Reply 20 of 86, by lazibayer
Stiletto wrote:
lazibayer wrote:
The table is misaligned by one return
So re-do it? There was also an error in the "truth table" in column 1 row 4 it seems. 😉
Thanks so much!
Reply 21 of 86, by lazibayer
Matsonic MS-5120 / PCChips M547
Clock generator: CY2961SC-1
122.27 KiB
No downloads
Reply 23 of 86, by lazibayer
GA-586TX3 Rev. 1.08
Clock generator: SC652EYB
Boring.
20.67 KiB
Reply 24 of 86, by matze79
Thanks,
586TX3 works nice, stable at 75Mhz K6-2 450Mhz.
168.37 KiB
193.12 KiB
177.41 KiB
R33 to Ground with 4,7kOhm Resistor.
(PAD near to Clock Generator IC)
Reply 25 of 86, by lazibayer
Motherboard: DTK PKM-0038S E-1
Clock generator: AV9107-03CN14
121.83 KiB
Reply 26 of 86, by dosgamer
Board: Asus PCI/I-486SP3G
Clock IC: Macronix MX8315PC
Datasheet: http://images.ihscontent.net/vipimages/VipMas … /MXMAS016-1.pdf
10.48 KiB
Certainly has some overclocking potential for a 486 board 😁
Edit: The MX8315 also has a pin that drops the CPU clock down to 8MHz when pulled low. This doesn't seem connected to anything/have anything to do with the turbo switch input that this board also has. Maybe the two could be used simultaneously?
Coppermine Celeron 800 @ 1.12GHz (8x140) - Asus P2B Rev. 1.12 - 256MB PC133 CL2 - Voodoo5 5500 AGP - SB AWE64 CT4520 - Roland SCC-1 - Intel Pro/1000GT - 1.44MB Floppy - ATAPI ZIP 100 - 120GB IDE - DVD-ROM - DVD-R/RW/RAM - Win98SE
Reply 27 of 86, by lazibayer
Not S7 or older but what the heck!
Shuttle HOT-637 V3
ICS9150F-04
source
Reply 28 of 86, by lazibayer
dosgamer wrote:
Board: Asus PCI/I-486SP3G Clock IC: Macronix MX8315PC Datasheet: http://images.ihscontent.net/vipimages/VipMas … /MXMAS016-1.pdf […]
Put a 5x86 on it and crank it to 80 x 2! 🤣 🤣 🤣
Reply 29 of 86, by lazibayer
Motherboard: MSI Premio TX5
It has two versions, one with ICS9148-04 PLL-IC
97.87 KiB
The other with IMI SC653AYB
65.64 KiB
cyclone3d reported in this thread that the ON-OFF-ON combination on the IMI version gives 100MHz bus speed! 😳 😳 😳
Reply 31 of 86, by cyclone3d
lazibayer wrote:
Motherboard: MSI Premio TX5 It has two versions, one with ICS9148-04 PLL-IC […]
So I finally had a chance to test out this board some more. I never did really do anything even when the 166MMX was in there except test the POST with some different video cards.
The events are not necessarily in the order listed below, but it makes more sense to stick with what I tried with the different CPUs.
I first put in a Pentium 233MMX that I recently received and I was able to get it to POST at a reported 250Mhz at the supposed 100Mhz fsb setting. I was also able to get it to POST at 300Mhz by raising the voltage to 2.9.
I tried all the way up to 3.1v and the only difference it made was that it reported 266Mhz when at 3.0v and 240Mhz when at 3.1v. Something is definitely screwy with that fsb setting.
However, it freaks out when it gets to the second screen where it should be listing the CPU speed, RAM, IRQs, etc. Just locks up. I think either the board is trying to run the PCI bus at 50Mhz at that setting or something else is going on like it needs more I/O voltage of which there is no adjustment for.
I also tried with a K6-III+ 450 and although it POSTED, even at the 4.5 multiplier at the supposed 100Mhz fsb setting it had the same issues as the 233MMX did. I tried all the way down to the 2.5 multipler and it still did the same thing. THE CPU speeds reported were way off. Guessing that is because it only officially supports the original K6 CPUs.
So I guess I am just going to make it into a 233MMX system and be done with it. I could run at the 75 or 83Mhz fsb setting, but I really don't need to as I have other builds in the works that will cover faster speeds.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 32 of 86, by lazibayer
cyclone3d wrote:
So I finally had a chance to test out this board some more. I never did really do anything even when the 166MMX was in there exc […]
Thanks for the tests! Sounds like the 100MHz setting is messing up the mind of the poor board's BIOS. 🤣
Reply 33 of 86, by lazibayer
Was curious about the possibility of overclocking the FSB of pentium pro. So far no luck.
ASUS XP6NP5: W48C60-414G, 2 jumpers, 4 combinations, 60 and 66MHz marked out and two others undocumented.
Gigabyte GA-686NX: PLL52C59-14LSC, 1 jumper
Micronics W6-LI: W48C60-404G, 2 jumpers, 4 combinations, 60 and 66MHz marked out and two others undocumented.
Reply 35 of 86, by infiniteclouds
Did you discover these through just experimenting with jumper settings?
I wonder if my AOpen X59 motherboard has hidden settings... I was disappointed when I saw it didn't have settings for lowering than 66FSB.
Reply 36 of 86, by lazibayer
Most of the settings are taken from the datasheets of the clock generators. What's the model number of your board's clock generator? We can try and see if there is a datasheet for it.
Reply 37 of 86, by infiniteclouds
is this what I'm looking for?
BjZhHHO.jpg?1
I never wanted to just haphazardly try other jumper configurations on here for fear of frying my board and/or GPU. The manual has configurations for 66, 68, 75, 83, 95, 100, 112, and 124 FSB speeds but give a warning saying that it only supports a maximum of 100FSB and that 112/124 is for internal test only. I'm only interesting in seeing if it can go below 66, anyway.
Reply 38 of 86, by lazibayer
The winbond chip is tag-ram. The half-cropped chip at bottom left is the clock generator.
