Building a 90s Gaming PC
Reply 20 of 48, by mr_bigmouth_502
^I like Pentium II systems purely for sentimental reasons, but I agree, a good Pentium III box is much better for gaming.
Reply 21 of 48, by brostenen
I would still go for a SS7 system. More flexible and better to "tune", if 486dx2 speed is needed.
Another great option that SS7 offers, is that it actually can handle CPU's from the original Pentium and up to K6-3+.
Pentium-III systems are more like uber-speed for really demanding 1999 games, and without cache enabled, you would get a slow system system. Like a 386dx40.
SS7's are the more flexible choice. 😉
Reply 22 of 48, by RacoonRider
awgamer wrote:
386 40(jumper set to 16/20/25/33/40, games from 86-92) adlib, cms, innovation, mpu-401:mt-32 lpt:covox
Jumper set? At least 90% of 386-40 boards do not have frequency jumpers. You can mount a DIP socket and swap OSC, that's all.
Reply 23 of 48, by awgamer
so get a 386 33, it's not even necessary, the follow up to the 386 25 in 1988 was the 486 25 in 1989.
Reply 24 of 48, by Skyscraper
Its hard to build one system to rule them all. I use one system for DOS another for Windows 98 and a third for Windows XP. Sadly I do not have dedicated systems for early speed sensitive games.
For DOS I would use a socket 7 or Slot 1 system with an ISA sound card. Be sure to get a CPU that can be down clocked to below 200 Mhz otherwise you will have to patch some games to get them to run. I often use a system with a Pentium 2 running at 2.5*66 Mhz. The same CPU can run at 4*112 MHz when needed. Socket 7 is a safer bet though as you have more CPUs to choose from.
For Windows 98 gaming I would build a really fast system. Somewhere between a Coppermine P3 1000 and a socket 478 Pentium 4 3066. My own system I use for Windows 98 gaming is a Tualatin 1400 with a Geforce 5900 Ultra and a Soundblaster Live.
Reply 25 of 48, by PeterLI
I recommend a OEM 486 and Pentium III box. Cheap and most games will run 100%.
Reply 26 of 48, by PhilsComputerLab
^^ Good advice. Getting complete systems can save a ton of time and money. Just got to be a bit patient. Bulk lot sales do pop up every now and then and most are not interested in getting so much stuff at once 😀
YouTube, Facebook, Website
Reply 27 of 48, by Darkman
thats true, its quite possible to get an OEM machine and modify it as you see fit .
Reply 28 of 48, by HighTreason
The problem with OEM is when you want to upgrade there may be evil proprietary crap to deal with and more likely limitations on processors and whatnot.
If you go that route try and find one that has standard form factor as it usually indicates it has been made with off-the-shelf parts that you can replace/upgrade later.
Reply 29 of 48, by Godlike
^^ True up here. If you have time for custom build I would definalety go with CUSL2, TUSL2 or P2B-F, ABIT BE/BH6 based system with Pentium III. I would recommend something from Voodoo line as well 3-5 or V2 SLI (Canopus, Diamond sic!). If you get bored with 3Dfx (never happend to me). You can go with Radeon DDR o Nvidia equivalent . This will play all 90s, even early 2k, it depends on GPU choice.
Personally I'm using ASUS iPanel Deluxe with my CUSL2-C motherboard, very useful device;)
ASUS P2B-F, PII 450Mhz, 128MB-SDR, 3Dfx Diamond Monster 3D II SLI, Matrox Millennium II AGP, Diamond Monster Sound MX300
Reply 30 of 48, by PeterLI
Right. When you are into hardware modifications / upgrading / specifications / bench marking custom is the way to go. When you just want to play some games OEM is the way to go. IMO. 🤣
Reply 31 of 48, by PhilsComputerLab
I had good experience with the few OEM gear I got. The Acer 486 has a very locked down BIOS and a single IDE port, but it has PS/2 ports, ISA, PCI, VLB slots and onboard ATI Mach 32 with 2MB and is rock solid. Finding these parts individually will cost you quite a bit. Got two Acer boards with Socket 370 and Intel Tualatin chipset and they are also mint. The equivalent AOpen board sells for 2-3 times as much.
Reply 32 of 48, by PeterLI
Indeed. I have bought stacks of OEM PCs from 8086 through Pentium III <= $75 including shipping here in the USA over the years. Hard to beat that value. Very often people list them without the CPU in the title or description. Just the brand & model #. Most eBay users search on CPU.
Good example: http://cgi.ebay.com/311254872416
This thing has not sold a few times already so I will get in touch again in a few weeks and offer $75 with shipping again (I did so this week). Eventually it will go for that price.
Other examples:
http://cgi.ebay.com/371022491746
http://cgi.ebay.com/281567132684
I do not like Compaq though. Something about the design turns me off. 😵
Even generic clones are cheap sometimes when they do not list the CPU:
http://cgi.ebay.com/321647260437
Anyway: people are always stating vintage equipment is hard to find on Vogons / VCF / AmiBay but this is not reality. There is so much out there.
Reply 33 of 48, by Godlike
Yea, go with "old computer" and other scrap names for search result. Some people don't care about computing and that way you can find something cheap. I like alway emotions when opening old computer with unknown specs. Life is beautifull;) As PeterLI wrote Ebay or other online/offline auctions!
Reply 34 of 48, by Skyscraper
I agree that not every OEM system is bad.
Even when it comes to XP era hardware some OEMs can be great.
I rate Fujitsu Siemens high when it comes to late socket 478 systems and early K8 systems.
As an example the i865PE motherboard d1627 is pretty much the best built s478 motherboard I have ever owned.
Here is a bad pic from the net.
During the Coppermine era Fujitsu Siemens mostly used Biostar boards which wasnt as good though.
Reply 35 of 48, by HighTreason
I can vouch for NEC in the P3 era. They often used ASUS boards for their Pentium III systems, I have an NEC Direction that has been heavily modified by it's previous owner (a Jazz musician, hence the machine appearing as 'JazzMan' on the network) for the worst and is currently a little borked.
Case construction sucks though, but heh, OEM crap, what did I expect.
478 systems will not run DOS games well as finding one with ISA is difficult.
Reply 36 of 48, by Godlike
OEM goes to non-hardware enthusiasts. Vogons for enthusiasts
Reply 37 of 48, by badmojo
Thanks Godlike, I've chiseled your commandment into a stone tablet. I have space for approximately 9 more.
Reply 38 of 48, by Godlike
You've state that with 1234 posts of yours! This is some kind of magic? What about this stone tablet?
Reply 39 of 48, by RetroGamingNovice
I think you could get early P4 systems to run 9x, plus VIA boards, provided the VIA boards have a PCI slot so that you can install an SB Live! 5.1 card.
PC hardware: Ryzen 5 4500, 32GB RAM, 1TB SN 570 /500GB 970 EVO Plus/2TB 970 EVO Plus/1TB 870 EVO,, RX 6600 GPU, Arch Linux/Win10 dual-boot
