Reply 20 of 22, by KT7AGuy
- Oldbie
Scali:
I was referring to your Silverado. I remember reading very negative reviews about the orb with the two fans, so I avoided it.
I remember reading about the Silverado and also the Swiftech coolers too. Cost is what always kept me away from them, but I wish I could have tried them.
One good and reasonably priced Athlon cooler I've found is the Arctic Cooling Copper Lite Silent 3. I'm mentioning this unit because they're actually still available. It's a great cooler with a major drawback: The fan is a non-standard item that is not easily/cheaply replaced. The guys at Arctic Cooling must think their fans are made of solid gold because getting an official replacement fan for these coolers is very costly. If the fan on mine ever dies, I'll probably just use a dremel to cut the fan off the base with the mounting clips. I can probably just glue a standard 80mm fan onto the base clips for a replacement. Still, that is an ugly hack.
Evert mentioned the Rosewill RCX-Z100 cooler. I purchased one of these as a backup a few years ago, but I haven't had a chance to install and test it yet. It looks like it should be adequate for a Thunderbird 1400.
