Reply 20 of 22, by j^aws
- Oldbie
wrote:You are welcome. I was somewhat surprised, that with the caches on, even deadly slow 10.7MHz Pentium perform about 33MHz i386. IPC gains, I assume and the 512kBy of soldered L2 on the board. Off they go and 1.6 is there.
I was badly surprised that memory settings did not played any role. I man... I set the memory settings to slowest (forget 2-2-2 burst, try 4-4-4 ... forget CAS 2, try CAS3 ... etc) and there was absolutely no difference. I hoped for 1.4 or 1.2... but no. Suxx.
If you haven't tried already, besides memory latencies, I'd try going through the BIOS and disable anything that sounds remotely 'speedy' - like shadowing BIOS and Video, PCI waitstates on so on... This might shave a few more off your benches.
BTW, I figured out how to use LandMark 2.0 without input:
... Use "LM20 /b"
wrote:The K5-75 is classic 50x1.5 CPU. It can be overclocked to 60x1.5 but that it is. 66x1.5 fail to post... What is even worser, at 7.14MHz FSB it also fail to post completely. And I already masex out the Vcore (3.5V), so there is nothing I can do. No way K5 post at such low FSB settings ๐
It could just be this particular CPU. If you have others, it maybe worth trying those out, especially if you can get 1x multi working.
wrote:Maybe K6 can work at such low FSB clocks? Who knows... but I definitively will try it. You know, K5 is not even a x86 CPU, but rather experiemental superscalar AMD cpu, that get the x86 instruction decoder in front of it and that it is... Maybe that is where it fails?
Another possibility will the the AMD K6-2, witch is not mentioned in the supported CPU, but I quess that it can work, or the bios can be updated to make it work... It does work in Asus TXP4 mobo anyway: http://hwbot.org/submission/2373822_
It would be interesting to get results for any CPU that POSTs, especially K6-II+/ k6-III+ CPUs (you can use Setmul on those to change multi and cache options). My results only go to XT speeds for K6-III+ CPUs, where the Turbo function literally destroys its performance in a good way. Presumably due to its on-die L2 cache.
wrote:So there IS a chance for AMD cpu to get into superlow clocks. But I would want CPU, that can be forced to low multipliers. I heard that Pentium Overdrive can be switched to x1 multiplier by disconnecting the fan. Then it switch to x1 in order to prevent overheating... Never tried it myself, but sounds reasonable and people used this there:
http://www.winhistory.de/more/386/xpmini_eng.htm
The thought of installing an OS like XP did occur to me, then I came to my senses. The only reason I can see to use speeds this slow is to run speed sensitive apps/ games... I can see the challenge though.
wrote:Another way is mainboard, that have good frequency control. The Asus TXP4-X use as clock generator the ICS 9169 PLL. That chip, however, cannot be controlled by software, because "do not have a System Management Bus connection or the FSB could not be set via System Management Bus. So there is and will be no program that supports these PLL's!!! There is absolutely no chance!"
http://www.cpufsb.de/FSB.HTM
This is a nice DOS utility to change FSB, but it has very limited PLL compatibility:
SMB.ZIP ver. 2.09: http://rayer.g6.cz/programm/programe.htm
wrote:But for some, 2MHz is possible on CPU too: http://www.youtube.com/watch?v=y3wkhDfzqlo (FIC 486-GAC-2 mainboard)
It would be interesting to see this setup benched relative to an XT 4.77MHz...
wrote:I'd call speed close in +-15% difference. More difference can be noticed clear, hence is not good for games linked to the timer.
I like the idea to find a single machine for retro games. The ideal result should support games from 1981-2001 times: full DOS/Win9x period, XT 4.77 - P3 600. I see philscomputerlab's researches in this direction. You do similar research. Some parts may be changed in the using of "retro machine", besides MB, drives, case.
What you are looking for in a single build is kind of a Holy Grail to find. I know a build from XT 4.77MHz - K6-III+ 450MHz is possible. And on paper, a build from XT 4.77MHz - P3 1050/ 1400MHz is also possible, but finding working parts is next to impossible...
