My First Super7 since 2001
Reply 20 of 23, by candle_86
it all boots, but its a 512k cache board, only advantage over my current board is the tag ram can cache more than 128mb and it has PS2 ports built in 🤣.
Also the board had the K6-3 333 set to run at 500, I took it down a bit, but it boots at 450 and loads windows at 400, so I'm content, should be faster than my K6-2 400 that I can't convince to run over 420mhz 🤣.
Reply 22 of 23, by elod
candle_86 wrote:
http://www.ebay.com/itm/Reburb-Dell-7D208-07D … =item27f9632f96
A geforce 2 MX is now bought for my system, the Geforce 256 DDR is messed up, so instead ill be getting an MX 32mb
Did you install the card? I'm planning to test the same on a Soyo board.
Reply 23 of 23, by candle_86
yes I did along time ago, it worked great. But i eventually swapped it for a Voodoo Banshee
