blank001 wrote:Really nice video. I'm thinking of reconfiguring my III+ rig now. I believed your games list all the way until deus ex 😉 You need a way beefier CPU for that no? That would be ideal for your 1400S / V5500 rig.
I just grabbed an audician from the UK! Very cool.
Yes, Deus Ex is clearly too demanding. The indoor introduction is not to bad, but step outside and it becomes too much to handle. Clocking the chip at 550 MHz helps a but, but I kinda wanted to show that the machine does have it's limitations.
alexanrs wrote:AFAIK many Slot1 CPUs have locked multiplies, and I don't think you can change multipliers on the fly on the unlocked ones. Too bad K6+ are pretty much non-existant here in Brazil, but hey, I've got plenty of space and older PCs to run those titles =)
And the lack of motherboard Cache means you can't have this "middle" speed setting. You might be able to import the chip from Germany or US. They shouldn't be hard to find.
alexanrs wrote:philscomputerlab wrote:There are benefits of being able to clock down to 133 MHz. 200 MHz could be too fast for some games. But, and I talk about this in the video towards the end, it's your machine. You decide if you want to be better at the higher performance end, or slower and more compatible for older games. It's all up to you 😀
I believe his question was why not just use a regular Socket 7. ATX form factor, jumpers for higher multipliers and USB keyboard support in BIOS are probably good reasons.
If one goes for an AT board, though, the system might be even more flexible. Using the jumpers to switch the FSB between 66MHz and 100MHz could make this even more practical (though not modern looking). One could always mod an ATX case, though, and fixate a latched switch to a bracket or an unused RS232 opening on the back (easier) or on a bay cover (harder to make it look good).
The main issue is support for these mobile chips. Later Super Socket 7 boards mostly support it, on older boards you might have to use a modified BIOS or something like that. With changing the FSB, and I could have mentioned this, or uses such a board, there are machines that allow you setting the FSB in BIOS 😀 Iwill does one I believe.
blank001 wrote:If anyone knows where to find a switch that fits over jumpers, I would be thrilled to know.
That said SS7 gets you 100Mhz FSB and AGP at the very least. Also are there non-SS7 boards that support K6-iii+ chips?
The CPU intensive windows games can ramp up to 5.5x100 when needed (although really better served by a different system).
You can put switches in the front panel. The newer boards use dip switches though. So that doesn't work. But keep an eye out for boards that let you change the FSB in the BIOS.
firage wrote:Is the 486 mode too fast for Ultima VII, I wonder?
Wing Commander VII is a game that won't work with the disabling caches method. Because, it turns the caches on 😀 It's one of the few games I know that does this.
anthony wrote:Many s370 and even 478 and 775 systems are able to run such speed affected games as wc1, testdrive3 with throttling management software. As for me, don't see any profits on super sok7
I've done extensive tests in this regard. A basic Slot 1 machine, with caches disabled, you get a 386 SX. Even old games like Indiana Jones and the Last Crusade will feel too slow. On a very fast Pentium III, like 1.4 GHz, Wing Commander becomes playable. But with such a high clock speed, fast memory, other issues crop up.
All I'm saying is that running a few benchmarks isn't enough to test this. You got to actually play a few games. Many games will also refuse to initialise the sound card on such a fast machine. The SS7 is simply the best platform for this.
Evert wrote:Awesome video and build Phil, but you should've used this as your background audio.
Thank you! Love your Indiana Jones references 😀
Skyscraper wrote:Nice video!
I have no issues with running many different systems for different games but I do like Super Socket-7 nonetheless 😀
Thanks!
squareguy wrote:Thanks Phil,
You just single-handedly drove the cost of that motherboard up by at least another $100. Thanks again, really.
Great video!
🤣 Sorry. Plenty of other great boards though. Asus, DFI, IWill, FCS...
PARUS wrote:Wow! Glad to see this! I always loved maximum-integrated systems. It's ergonomical, it's beautiful, it's elegant. Thank you. I got a lot of pleasure during watching this video.
Thank you for your nonstandard decision. I'm not indifferent for these things and made myself a similar computer. Yours can 1986-2000, great! My machine is slightly faster and can play the games 1993-2009. It is a middle-later DOS, all Win9X, all WinXP and a little part of Win7. If I do not break the rules I can show it here. Not videos but photos and describe.
P.S.: slot-1 CPUs can't play many old DOS-games with any multiplier. The reason is architecture of Pentium Pro/2/3. But they are 100% compatible with middle-later DOS-games, 1993+. My system is based on newer CPU and compatible 100% with 1993+ also. But it can work with a lot of older games 1990-1992 too.
Sure, please share your machine!
Thanks for the kind words. I know my thinking is often a bit non-mainstream, but I also know than many have similar thoughts. And even if you don't, there is always something to learn and apply to your own project 😀
