Problems with Promise Ultra 100 TX2 - 486
Reply 20 of 24, by feipoa
Does soft reset work?
Reply 21 of 24, by AvalonH
Cntrl Alt Del resets the computer in Dos ( this is using using the 486 Asus AP4 motherboard with this card).
Reply 22 of 24, by feipoa
I recall soft resetting working with the SATA TX2plus. Did you try Ultra66, 100, 133 TX2 IDE cards with soft reset?
Reply 23 of 24, by AvalonH
feipoa wrote on 2020-03-19, 01:26:
It also works with the S150 TX4. Don't have the Ultra66, 100, 133 models to test.
Reply 24 of 24, by AvalonH
I tested a 2005 Adaptec 2410sa PCI-X card. This is a 4 port SATA raid controller. It boots and works in non-raid jbod mode using a connected SSD with DOS on a 486 Asus AP4, (420ex chipset).
Same with a HighPoint RocketRAID 1820A 8 port SATA raid controller. Bit overkill for a 486 but good to know both these 64bit PCI-X cards are working in 32bit PCI2.0 slots.
