alexanrs wrote:This is an idea:
That was my thinking, yes.
Get the enclosure from a busted CD/DVD drive, use some plastic/rubber/tape to isolate the inside, fixate the components (and zip-tie stuff like the UM-ONE), make a cable with a female DIN conector and use a perfboard (or etch a simple board) with a molex connector (for power - as I do not trust getting it from the sound card) and a waveblaster connector. Install MUNT, configure its ALSA server and aconnect to bridge the MIDI in to MUNT and have that start automatically. Then just run a flat cable from the drive to the sound card. Oh, and you might need to add a little buffer opamp for the line out, taking advantage of the waveblaster's 12V and -12V line and put a decoupling capacitor between the USB sound card's line out and the IC. Oh, and using an optocoupler between the header's MIDI pin and the UM-ONE's MIDI input is probably needed as well.
For an internal solution, the interface isolation components could go on a daughtercard or in the case. The real-estate required would be minor. The molex to Pi interface could be a simple dongle.
IMHO making it an extarnal module would be more useful, even replacing the UM-ONE with something like this, adding a Line Out jack and a separate power brick.
I think that the required components would be small enough that you could pick the form factor. Obviously a larger box allows for more features. I was wondering about one of those 5.25" storage drawers with a two line led display mounted on the front.
