dyinginformant wrote:
🤣.  You are quite the character Snover.  😁
 Yeah, even his parole officer likes him...Oh wait..Is it ok to mention that?
 It's not so much that we are having a continuing discussion.  I emailed him and he replied back.  Quite promptly too.
 Good to hear. Apparently there was a nasty "exchange" some time back about the BUILD games. Apparently, there were people writing him and demanding that he fix various bugs within Duke Nukem 3D, BLOOD, etc... He was a little ticked as he had not written those games but the "engine"
 behind them and apparently it grew into a nasty argument from there.
 Really guys, I appreciate all of your help.
 Then where's my hug? Ok, I'm kidding.
Back to Duke...
WOW, Nicht Sehr Gut, you sure said a - um, keyboard full?
 Ok. To simplify, I will type all future replies in a mixture of Latin and Sanskrit.
Ok, I'm kidding again.
I'm not sure how to run it without VDMSound disabled.
 Eh? That apparently means how to run it with VDMSound. Triple-negative. My English teacher would pitch a fit.
 I have a shortcut made with VDMSound which makes it full screen DOS (don't know how else to get it full screen).
 No, just right-click on the game's .EXE or .BAT and choose "Properties". Click on the tab named "Screen" and choose "Full-screen", then OK.
I tried to just double click the short cut - same effect as right clicking on run with VDMSound.
 If you're clicking on the .VLP shortcut, that's expected. If you're clicking on the game's .BAT or .EXE file, that's not right. If needed, temporarily rename your .VLP shortcuts.
Also I just used the normal command prompt, so VDMSound was not running at all.  I did get sound.  Duke talked very scratchy and slow-speed.
 That's the built-in emulation. Like I said, it's poor.
 How can I use VDMSound AND the Windows XP DOS emulation?
 That depends on the specific configuration you're trying to run. Basically you disable whatever function the VDMSound shortcut that you want the XP emulation to handle. You just have remember to match up what settings the game wants with what your computer has (IE:Built-in SB emulation uses IRQ5, the Default for VDMSound SB emulation is IRQ7.
 Or, what is this work around you speak of?
 It's built-in to the OS. Not something an end-user can access. Vlad, however was able to use it to allow VDMSound to play Digital audio for BUILD games.
 And how come you can set the resolution manually, but not the refresh rate?  What about the Vsync?
 Basically, because it's DOS you're dealing with. DosFreak may come up with a better answer, but it won't change anything.
[B] I don't know why VESA modes are so special...
 Because they ran into a burning building to save my puppy, and I owe them everything because of that.
Ok, that was another lie. And completely irrational as well...
I don't think there's an answer that can appease you here. These all have to do with DOS standards on the PC, which goes all the way back to technology from the 1970's. The older thing you tend to run, the more frequently you'll tend to come across these technical issues.
[B]It's not so much how the hardware reacts to DOS, it's how hardware, and Windows XP, reacts to the simulated DOS environment.  It's like it KNOWS it's not the real thing, and it wants to be mean to you or something....
 Yep, and when you're not around it connects to other computers on the Internet and starts bad-mouthing you; spreading rumors and innuendo, as well as using your login name to access various porn sites, then trolls various Macintosh forums starting flamefests before bailing out with comments like "YOU ALL SUXORS!!"
No, ignore that irrelevant tirade above. It was written by my Win98SE out of jealousy over WinXP.
Actually, it more like an "environment" issue. A fish in a lake may be fine. Place the fish on land, and it's in trouble. The fish is your DOS-game, the lake is DOS, and the land is WinXP. The emulation of DOS within XP (the Command Prompt) is like a shallow puddle of water on the land: It's better than nothing for the fish, but it's not enough. The best place for the fish is the lake, where it was originally meant to be.
The best place for your DOS-game is on the hardware/OS for which it was originally designed. Since that's not an option here, we try to find ways to make XP emulate the original environment(you can think of that as a fancy aquarium if you want).
*blech* I hope that's enough. I've overdosed on analogies...
[B] Dual booting may be good.  But I only have Windows XP on here. I had to get it activated.  I hope I don't have to uninstall it, install Windows 98 and then reinstall XP.
 Well that would be the easiest to explain, but it would probably be better if you used a partition manager to make some space available on your drive for another OS.
[B] Heck I don't even know if it's possible
 If you have something like an "emachine" PC, it might not be... They use a non-standard "restore-CD" that has no flexibility on installations.
[B] THANK YOU lousy cheap piraters who make my life harder
 This is so as to not have them confused with the high-quality expensive pirates who make our lives easier.
Sorry, I'm in a bit of a Monty Python mood right now...
On a serious note, if you haven't already done so, copy all the WPA.* files inside your windows/system32 directory to a floppy and store it in a safe place. That way, if you had to re-install you can copy them back after a new install without having use activation again (of course, if you change any hardware after activation it's not going to work).
[B] However, I may need to learn more about my hardware.
 Good thinking. Try this:
Go to http://www.navsoft.cz/ and download his NSSI software (under the products button). Put that in a new Folder and expand it by running it. Copy those files to a bootable floppy. And run NSSI. Boot with the floppy, then run NSSI.EXE. Use it to generate a report. Then upload the report here.
[B] This is very annoying, and I hate all manufacturers who kiss the past good bye and make it harder for us to enjoy the oldies.
 That's way the market is now. Most people want cutting-edge, 3D, surround-sound, multiplayer games; so that's where you'll find the concentration of resources.
[B] It's not like we don't buy new games too! Okay, so the newest game I have is Elite Force,...
 I think my most recent was "Summoner". Got that because it was 50 cents.
Heh. I love Half-Price books.
[B]... aggivated to see all these old game boxes in my closet that are a thing of the past!  I won't let my money go to waste (from way back when),...
 Heh, computer-people are more dedicated to their hobby than just about anyone.
"Forget your music CD's, I'm sticking with my wind-up Victrola!"
http://www.victor-victrola.com/
[B]BTW, is there a step by step tutorial on setting up a dual boot when XP is already installed?
Hrmm... http://www.winxpfix.com/page5.htm for now. Will try to find a better one later...
[B]Oh geez, sorry for making you read all that.
 Consider this replay as payback.
