Good Socket 478 XP build
Reply 20 of 33, by PhilsComputerLab
Lovely graphics card and I like your test bench, reminds me of my setups 😀
Regarding the cooler, there are quite a few versions. The better ones have a copper core, they should be good for 3 GHz at least.
YouTube, Facebook, Website
Reply 21 of 33, by Indrid Cold
Thanks Phil, I'm your great fan 😉
and thanks for your info about the heatsink, I must check again - I've got many of these through years.
Reply 22 of 33, by dr_st
I have a similar build (after the previous P4P800-E died, it was replaced with a P4C800-E, but otherwise left the same).
I recommend 2GB RAM, especially for a fully patched XP. 6600GT is the card I have in it as well, and it's been rock solid, but as you know, YMMV.
Reply 23 of 33, by Indrid Cold
Testing in progress! At the end, I've left the PSU (after a good cleaning) I've found inside this case just yesterday:
Reply 24 of 33, by Indrid Cold
3DMark06:
CPUID:
GPU-Z:
Reply 25 of 33, by agent_x007
I would advise updating GPU-z and CPU-z.
Reply 26 of 33, by candle_86
uh why, they arn't gonna tell him anything new about parts from 2003-2004
Reply 27 of 33, by Indrid Cold
Can't see why, so useless...
Reply 28 of 33, by agent_x007
GPU-z displays TMU number from 6.7 version and can show/record VRAM usage.
Newer CPU-z can do benchmark tests on CPU.
Reply 29 of 33, by Indrid Cold
Thanks for your advice, I'll give it a try - CPUID and GPU-Z you see in my screens are the versions included in Windows XP ICE edition V6 😉
Reply 30 of 33, by Indrid Cold
I have another Creative SoundBlaster Live! in my closet, can it be useful with this configuration? Or the sound board integrated in the P4P800-E Deluxe is way better?
Reply 31 of 33, by dr_st
I don't think the onboard audio is better overall. What I liked about it is that it was 8-channel (one of the first boards to feature 8-channel) with a full set of 6 jacks. But at least on my unit it was prone to PCI interference causing static noise. I eventually turned it off and went with an Audigy 2 ZS.
Reply 32 of 33, by Indrid Cold
Thanks dr_st, so I guess I should try it?
Reply 33 of 33, by dr_st
Well, if you are not experiencing any issues with the onboard audio, and you are not lacking features - I'd just leave it be...
