Remove Pentium 1 heatsink
Reply 20 of 20, by H3nrik V!
Minok wrote on 2025-01-15, 21:04:
Trying the freeze method as well. I soaked the chip+heatsink in a bowl of water first. There is a good razor blade high slot between them except for two strips along 2 of the edges , where the real adhesive sits. So I’m hoping as it freezes they ice hydraulic pressure may break the glue bond as well. Will see.
The attachment IMG_0751.jpeg is no longer available
As in you're using the water's expansion when freezing to pop it off? I wouldn't do that, it could stress or crack the ceramic material as well
