Alternative to _INMM.DLL for Windows 98?
Reply 20 of 21, by fixxx
I started messing around with PCem recently, which is pretty fantastic btw! I found that to get _INMM.DLL to work correctly with .OGG files in Win9x, this must be installed: http://downloads.xiph.org/releases/oggdsf/ogg … s_0.73.1936.exe. It is a .OGG DirectShow filter pack.
See this link for much more info regarding updating Win9x codecs:
https://msfn.org/board/topic/143737-2010-code … ck-for-win9xme/
Reply 21 of 21, by songoffall
Another note. Couldn't for the life of me make _inmm.dll work with Quake 2 - there was just no audio - and if you have the same issue, here is a solution. Just install Winamp and use it instead of DSHOW in _inmm configurations. Winamp 2.x to be precise, because newer versions will have a much higher performance overhead (even 2.x cut my Quake 2 performance on P3 in half, which is fine in 640x480 3dfx OpenGL mode, but it is mostly unplayable on my P2).
Pentium 2 300MHz/Matrox Mystique/Sound Blaster AWE 32 Value
Pentium 3 733MHz/3dfx Voodoo 3 3000/Aureal Vortex 2 (Diamond Monster Sound)
Pentium 4 2.0GHz/GeForce4 Ti4200/Sound Blaster Live!
Core2Duo Q9400/GeForce 8800GT/Creative X-Fi Titanium Fatal1ty
