SB 2.0
Reply 20 of 43, by lightmaster
oh noes the *bandonware word again! :p
Reply 21 of 43, by Gubbl
I really don't know what abandonware have to do with the problem.
So anyone who wanna help me out here?
Reply 22 of 43, by lightmaster
sbtype=sb2 ?
Reply 23 of 43, by Gubbl
I've tested it with all the compatible sound blaster emulations in dosbox. First of all with sb2^^
There must be a problem with FM feature of the emulation...i think so...perhaps. 😉
Reply 24 of 43, by robertmo
game uses IRQ 5 as default
you must have in your config.sys
for sb2:
DEVICE=C:\SB\DRV\CTSB2.SYS /UNIT=0 /BLASTER=A:220 I:5 D:1
DEVICE=C:\SB\DRV\CTMMSYS.SYS
for sbpro1 and sbpro2:
DEVICE=C:\SBPRO\DRV\CTSBPRO.SYS /UNIT=0 /BLASTER=A:220 I:5 D:1
DEVICE=C:\SBPRO\DRV\CTMMSYS.SYS
for sb16:
DEVICE=C:\SB16\DRV\CTSB16.SYS /UNIT=0 /BLASTER=A:220 I:5 D:1 H:5 /WIN95
DEVICE=c:\SB16\drv\ctmmSYS.sys
In DOSBox you will have to boot real DOS from a hard disk image
Sample usage of a harddisc image in DOSBOX
additionally you can use sb16 fm driver from pizza tycoon (sound.com from sound folder)
you can also copy all the sound effects from sound folder from pizza tycoon to have better sound effects. Although i noticed game crushing when exiting cause of that, but who cares about exiting 😉
Reply 25 of 43, by Gubbl
Big thanks for your help but I think i need assistance with this explanation.
Up to this point i use(d) DFend Reloaded for starting DosBox and the games in there, so I don't understand how to boot MS Dos 6.22 with DosBox.
It would be perfect if someone has a blank or MS Dos 6.22 Image for me to mount. Perhaps i can do it alone then.
I'll try the procedure in a few hours. Hope it will work. ^^
And one question: Why it doesn't work with normal DosBox booting?
Reply 26 of 43, by Qbix
Rank DOSBox Author
DOSBox Author
one of the device drivers adds a device in dos which the driver reads.
dosbox doesn't allow/support adding such devices in its internal dos.
and no we don't have an empty 6.22 empty for you as that is illegal to share.
Water flows down the stream
Reply 27 of 43, by HunterZ
I wonder if any of the programs that load .SYS drivers from the DOS prompt would work for this in DOSBox's internal DOS?
Reply 28 of 43, by Qbix
Rank DOSBox Author
DOSBox Author
well if those .sys drivers create a device that they expect to accessable => nope
Reply 29 of 43, by robertmo
dfend allows creating a bootable hdd image
Reply 30 of 43, by ripsaw8080
Rank DOSBox Author
DOSBox Author
CTMMSYS.SYS creates a character device named CTMMSYS$, which the game's sound driver tries to open, and just loading it with DEVLOAD or whatever is not enough to make it work.
Reply 31 of 43, by Gubbl
Waaahhh. Sorry for PMs. 😉 I thought this is just so detailled that it is too much for this forum.
But: It works now. I did a little trick.
I created an HDD Image with VMWare Workstation and installed MS DOS 6.22 on this image with all drivers and things i need. Then i take this image, load it with isobuster and "reimaged" it to an iso file. I mounted this iso file with DosBox and booted from this mounted iso. Then i reinstalled the sounddriver for SB16 and changed the config.sys lines as robertmo said.
Restart
Still no sound, cause the sound.com needs a SET BLASTER String within autoexec.bat. The lines in config.sys are not enough.
So I added one line to autoexec.bat:
SET BLASTER=A220 I5 D1
Restart
Start the programme and sound is working well.
Thanks a lot for the hint of booting real dos with the gread DosBox emulation shell. 😉
And sorry for my bad english...normally i speak a little better franconian german.
Edit: Perhaps one more question.
I mount the hdd image as c: and i boot from it. How can i mount another drive to get it into this dos? I tried to mount more hdd images or folders but dos always says "invalid drive specification".
Perhaps it is possible to mound it as cdrom? CDrom driver are installed within this Dos
Reply 33 of 43, by robertmo
i think you have to mount all images first and after you boot from one, all other images will be available too
Reply 35 of 43, by robertmo
i just imgmounted two different hdd images booted and have both available
Reply 37 of 43, by HunterZ
You can't have a CD image mount stick when booting from a floppy/HDD image though because DOSBox does CD mounting via MSCDEX emulation, which goes away when booting a "real" OS.
Reply 38 of 43, by robertmo
why do you want more?
Reply 39 of 43, by Gubbl
To get the games on the hdd. 😉 If you really take an empty image and make a partition, then you have to install dos on it. OK, you can mount disk images for that. And after that? How to install the Sound drivers when I have no disk image with them?
Ah I see, there is an extra in Defend Reloaded to create disk images from HDD folders. 😉 But it would be better if a CDROM drive could be integrated. But I think its not nessesary. You can use any other virtual PC programme to install MS Dos and take all you want to the hdd.
