Keyboard is locked... unlock it..?
Reply 20 of 25, by psychz
From what I gather, keyboard errors are the first thing to happen after severe battery corrosion on 486 boards, since the the barrel resides just below the AT kb connector and above the controller on the majority of those motherboards, so checking for continuity in those areas should be of help. Also check the back of the board. Some ICs have a bit long pins that tend to short with each other causing all sorts of issues, had this happen once with a kb bios chip resulting to "keyboard not found" error.
Stojke wrote:
Reply 21 of 25, by blacksn
I have the same board and the same problem. Gow to fix it?
AMD Am5x86-133ADZ/Shuttle HOT-433 256Kb/4x16Mb SIMM EDO/ATI Rage XL 8Mb/Ultra100 TX2/WD 400BB-60DGA 40 Gb/Opti 82c861 USB/ESS1868/RTL8139/CD-ROM NEC CD-3002a
AMD Am386DX40/Digicom 386P/8x1Mb SIMM FPM/Trident 8900 1Mb/512 Mb CF/ESS1868/CD-ROM NEC CD-3002a
Reply 23 of 25, by blacksn
Pins 7 and 33 of HT6542 are shortened to ground. Pin 34 is wired to keyboard lock connector (pin 4 of 5, 5th is gnd). These pins is not shortened. Is it ok or not?
Reply 24 of 25, by jakethompson1
blacksn wrote on 2020-09-26, 09:43:
If you want to go hardcore, if you pull and upload an image of your bios it may be possible to patch the keylock check out of the bios.
I wonder if Artex ever got it working.
Reply 25 of 25, by blacksn
Bios is soldered into board. I cant boot OS to read rom and have no soldering station.
