Best Socket 7 AT motherboard
Reply 20 of 30, by goodtofufriday
nforce4max wrote:
Socket 7 hands down as you get a wider range of support and can emulate slower systems so you can enjoy dos games at more appropriate speeds. Slot 1 is more of a pure 9x and xp platform for late 90s and early 2000s games.
Thanks! ended up getting the below. Its supposed to be a clone of the pcchips m577 super socket 7.
http://www.ebay.com/itm/181735304307]
now to try and find replacement usb and audio ports for the headers.
A fixer of things. I also broke those things.
Reply 21 of 30, by noshutdown
oerk wrote:
Are we talking Socket 7 or Super Socket 7?
If Socket 7, I'm voting for the Asus P55T2P4.
t2p4 is a cult board for me aswell, except for the problematic rtc component, thats why i am going after the atx version of xp55t2p4 which uses coin cells.
There are other games than Doom 😵 Take Test Drive 3 or Wing Commander for example... a 486SX25 is too fast for those.
maybe so but, you can easily slow it down even further with turbo buttom or undocumented clock jumpers, which usually provides 8 or 16 mhz in combination with disabled onboard cache and slow dram timing.
Reply 22 of 30, by oerk
goodtofufriday wrote:
Thanks! ended up getting the below. Its supposed to be a clone of the pcchips m577 super socket 7. […]
That's a lot of money for a PCChips board!
The coin cell mod for the RTC is quite easy to do 😀
Reply 23 of 30, by goodtofufriday
I got him down to 45. Abd some old reviews andantech and a russian site said it was pretty good.
But ueah i dont really know the value of the equipmemt for this era. Now with video games i could tell ya the average price for any game aha.
Going to get me a k6-3+ now
Reply 24 of 30, by brostenen
gdjacobs wrote:
brostenen wrote:
I have a P-133 on a FIC PA-2013, TNT2-M64-PCI, 32mb Ram. Disabling cache makes a nice 386/486.
Don't know what to do with it, other than I did the build for the fun of it.
I don't have enough antistatic bags, so I had to put the hardware into a case. Hence the build.
Feel free to share that board with me... 😎
I can post pic's....
The machine will be resting on the shelf, untill the time comes, when my 486's are both dead.
Reply 25 of 30, by brostenen
Why mess around with an RTC mod?
I go for a complete RTC replacement, it's not that hard to do.
Get some of that cobber desoldering wig, the threaded type on a roll.
Place it on top of the solderspot that you wish to remove tin from.
Place a hot solderiron on top and wiggle one millimeter to each side.
It will suck up the old soldertin. From here its just a matter of
installing a socket, insert a new battery and secure with a zip tie.
Or cable strip, as it is known in other places.
Reply 26 of 30, by oerk
Because coin cells are a lot easier to come by - and cheaper.
Reply 27 of 30, by brostenen
Cheaper, yes... Not that much, unless you think that 2 to 8 dollars for an essential part is expensive.
I don't think that something like 5 dollars with free shipping is that bad.
And they are probably one of the easiest part to come by. Just get one on eBay.
Can't be that difficult.
http://www.ebay.com/sch/i.html?_odkw=motherbo … attery&_sacat=0
Reply 28 of 30, by Scraphoarder
If you go for a P2 or P3 slot 1, maybe look for a Dell Optiplex GX1 that has an interesting slowdown utilty for dos. Just use keys Ctrl-Alt-\ or Ctrl-Alt-# and you adjust speed om the fly. I have one but its a slim desktop without an AGP slot. Dont know if the tower models had AGP.
Reply 29 of 30, by candle_86
oerk wrote:
Yes, certainly. Anything above a DX4/100 will do this. I'm personally satisfied with Doom on a DX2/66 w/ ISA graphics. […]
But I'd like to go up to being able to play doom extremely well. is a 200mhz mmx enough for this?
I'm alrady making a 98/XP machine (which is where my PC knowhow starts) so the machine in question doesnt really need to venture in the 98 era of gaming.
Socket 7 would be perfect then.
What would be the process to slow down a pentium 2/3 for 486 gaming?
Lowering FSB, lowering multiplier if possible, disabling caches. Though I've often heard that a P2 with disabled cache will be TOO slow.
it is go look at reviews of the Celeron 266 and 300, not the 300A but the oriignal. A celeron 300 compared to a Pentium 100 🤣
Reply 30 of 30, by noshutdown
thats obviously exaggerated, the celeron without l2 cache is "only" 30-40% slower than the pentium2, and you need a very slow mainboard(sis620 for example) to really slow it down, or it would be saved by bx's superb memory performance at least to some degree.
