DOSBox And Physical Floppy Drive Question
Reply 20 of 83, by plamy1969
Ok, that's what I'm talking about:
https://www.gearslutz.com/board/attachments/r … n98bootdisk.zip
The .exe inside the archive makes a Win98 boot diskette which includes the little program I mentioned - EPSDISK.EXE which is DOS and work best in Win98. Many years ago I used this program 100% successfully on Windows 98. But now is different...
Type "win98bootdisk" in Google.
Reply 22 of 83, by Jo22
plamy1969 wrote:
Did someone take a look at the program so that I can get some more help?
I downloaded it, but I've to do several other things right now, too (fixing SQ3 recordings, dumping a chip, family..)
If it is okay, I'll look at it early next week.
In the mean time, I can give you another tip. Perhaps this will help you even more:
You can also boot DOS from an USB pen drive.
It can either be a start-up floppy of DOS 6.x or FreeDOS Live CD.
Your real floppy is then accessible as B: drive (handled by the BIOS).
Two programs I know of are..
a) HP USB Disk Storage Format Tool
b) Rufus
The HP thing creates a USB-based floppy. It will maybe ask for DOS files, but already has the boot sector.
Rufus can create a bootable pen drive from any type of bootable media.
Depending on this type, it either emulates a HDD or a CD-ROM when you boot from you pen drive.
So in theory, you could also use a Win98SE CD as a source for this.
Sorry, I'm not good at explaining such things.
Hope you figure it out.
Reply 23 of 83, by plamy1969
Ok, look at the program when you can. Below I attached two files that EPSDISK.EXE should copy and write to the already formatted with EPSDISK diskette.
Following the instructions of EPSDISK Read me file you can easily see how to write at least one of these files to the diskette.
If you do it successfully, then you can use EPSDISK command (D)irectory,so if the (C)opy or (W)rite is done correctly, the (D)irectory command will show all the newly copied or written contents on the diskette. This will prove that everything is done properly.
http://www30.zippyshare.com/v/nuQiQUUx/file.html
http://www14.zippyshare.com/v/LDvyuytb/file.html
Reply 24 of 83, by Jo22
No problems. I'll have a look at it in 1-2 days. 😀
Reply 25 of 83, by Duffman
so this program is meant to format a floppy disk to ensoniq's proprietary format?
MB: ASRock B550 Steel Legend
CPU: Ryzen 9 5950X
RAM: Corsair 64GB Kit (4x16GB) DDR4 Veng LPX C18 4000MHz
SSDs: 2x Crucial MX500 1TB SATA + 1x Samsung 980 (non-pro) 1TB NVMe SSD
OSs: Win 11 Pro (NVMe) + WinXP Pro SP3 (SATA)
GPU: RTX2070 (11) GT730 (XP)
Reply 26 of 83, by plamy1969
Yes! And not only to format, also to copy Ensoniq images, to write Ensoniq files (music instruments), etc.
But all I could successfully do is format only, can't (C)opy and (W)rite. The other commands are not so important to me.
Long time ago when I used Windows 98 and XP, there was not problem. But now under this Win98bootdisk something goes wrong. EPSDISK.EXE can't see any Ensoniq file.
Reply 28 of 83, by plamy1969
lightmaster wrote:
Maybe dosbox-x has better floppy disk support
Maybe, but will dosbox-x recognize any other drive except floppy? If I run EPSDISK.EXE via dosbox-x, do you think the program will find the files I need to write to the diskette from any other drive/directory? If yes, what do I need to do in advance?
Reply 29 of 83, by Jorpho
I am not clear on why you would think otherwise.
I could try to guess, but why don't you tell us more about exactly what you've already tried to do in DOSBox?
Reply 30 of 83, by plamy1969
With my little experience I know that I can run EPSDISK.EXE in DOSBox by simply drag-and-drop the program to DOSBox. Then DOSBox runs EPSDISK.EXE showing all its commands as well. But to use the program to format, copy, write, etc. the diskette, I need to mount the floppy drive. If I do that, I lose EPSDISK.EXE with all its functions. I can't mount more than one drive at a time, so it's up to here. While running EPSDISK.EXE in DOSBox, I tried typing the .efe file location on my hard drive, but I get en error.
Anyway, instead on too many posts, anyone with experience can try do to what I need. I already uploaded EPSDISK.EXE and two files that I need to write to a diskette. So, if anyone does this with success, please share the way.
Reply 31 of 83, by Jo22
I downloaded them, but my main PC is still broken.
That file is a self-extractor, so I can't open it easily on my tablet or my vintage Mac.
I'll see what I can do after weekend.
Edit: Plamy, do you have a card reader ?
Reply 32 of 83, by Jorpho
The "win98bootdisk.exe" appears to be made using https://archive.org/details/tucows_222418_Floppy_Image. I have converted it back to an IMG and attached it here. It mounts fine in DOSBox using "imgmount".
What exactly do you mean? You can put EPSDISK.EXE in C:\whatever, and then type "mount a a:\" in DOSBox followed by "mount c c:\whatever". Then you keep both the floppy drive and EPSDISK.EXE. What's the problem?
    win98bootdisk.zip
    375.96 KiB
    52 downloads
Reply 33 of 83, by plamy1969
What to do with win98bootdisk.img that you attached? Would you explain exactly step-by-step what you did, please? What do I have to type literally in DOSBox? And did you really try to copy and write the attached files to a diskette successfully?
Are you sure EPSDISK will work with mounted c: since my drives are NTSF formatted? If I read carefully, EPSDISK can't work with drives which are not FAT formatted.
Reply 34 of 83, by Jo22
Thank you, Jorpho!
The filesystem is handled by the OS. In this case, it is DOS.
DOSBox uses an emulated DOS with a virtual filesystem (except if you do boot another DOS).
Real DOS can't read NTFS by default, only FAT. It is possible to add limited NTFS support with a special driver, though.
Reply 35 of 83, by plamy1969
Jo22 wrote:
Thank you, Jorpho! […]
Thank you, Jorpho!
Yes, I have a card reader, also usb stick. Do you think it's a good idea to format a card or an USB stick on FAT32, then to put epsdisk.exe and .gkh, .efe files on it, so that it can be recognized by DOSBox and EPSDISK.EXE for totally successful operation?
Reply 36 of 83, by Jo22
Quick update, I tried the program in DOSBox and it can't access my floppy drive on the raw sector level.
I tried both the /volume/nameofmedia path and the /dev/disk1 path. And I'm using the G3 build for OS X.
Mounting the floppy on the filesystem level via /volume/nameofmedia works fine, though.
I can see files on my diskette by using DOSBox's internal DIR command..
    12.75 KiB
Reply 37 of 83, by Jo22
Good. Do you also have a spare compact flash card ?
Reply 39 of 83, by Jo22
plamy1969 wrote:
What do you call a compact flash card? Tell me your idea.
I mean an ordinary CF card.
https://en.wikipedia.org/wiki/CompactFlash
An SD card could also work instead, but I'm more familiar with CFs.
