386SX wrote:Jade Falcon wrote:The only thing holding it back is the 1.8ghz clock speed.
There I'm recall you could get upto a 2.4ghz 6 core cpu for lga1207 a […]
386SX wrote:But these extreme old configs can compete nowdays in modern tasks?
There I'm recall you could get upto a 2.4ghz 6 core cpu for lga1207 and I upto something like 3ghz for a 4 core cpu.
I bought the 1.8ghz cpu's are they pull 40w and have a max TPD of 60w. That and I got 2 for 4$, hopefully they will work with my mobo.
Yeah the only problem I see is the total wattage request when oc... 😵
I did not really plan to OC them. The board I bought is a old MSI board from around 2008-2010, MSI did not use the best VRM back then and I don't want to kill the board.
one look at the VRM and most will not OC it
