Voodoo3 3000 vs TNT2 Pro
Reply 20 of 23, by PhilsComputerLab
Fusion wrote:
Hey Phil, any games you'd suggest I'd throw at these cards? I'm really just trying to justify a reason to use this TNT2 Pro. 🤣 I test with 3DMark, Q3 and RtCW. Looking for something that isn't a Quake engine game. I wanted to bench Soldier of Fortune, even though its Q2 based, but the demo1.dm2 I found won't work with the version I have so that backfired.
Got Unreal? At the start press ~ for the console to come down and type timedemo 1
I usually take the third run.
Attached is fraps that runs in 98. For a quick and easy test just find a spot in your favourite game, save the game, write down the FPS, then change resolutions. Give you a rough idea.
But you can also log some actual gameplay if you want.
Reply 21 of 23, by Fusion
I have Unreal but that gives the Voodoo a unfair advantage. 😉
Pentium III @ 1.28Ghz - Intel SE440xBX-2 - 384MB PC100 - ATi Radeon DDR 64MB @ 207/207 - SB Live! 5.1 - Windows ME
Reply 22 of 23, by PhilsComputerLab
Oh I thought you're going to quickly checkout resolution scaling to see if the CPU is fast enough.
Reply 23 of 23, by Fusion
Oops my bad.
No, I'm looking for games that I can benchmark and compare the 2 cards. I've learned today that the "dynamic lights" option in Quake 3, when turned off gives a nice boost in fps, nearly 8fps! With no noticeable quality drop unless you're looking for light flicker from explosions and rockets, etc.
