Reply 20 of 21, by Justin1091
Voodoo2 SLI never failed me in DOS. Some games crash in glide mode when you have EMM386 loaded. Try disabling it and try again.
For drivers, you can download a package and unzip it. Then put glide2x.ovl and in your SYSTEM directory (or was it DOS directory? I don't remember). Games that don't come with drivers in their root directory will look there. I use this method for my Win 3.11 + voodoo2 installation (as 3.11 doesn't have 3dfx drivers).
Games I remember playing:
Lands of Lore 2
Redguard (needs emm386.exe disabled)
Carmageddon
If you want higher refresh rates in DOS glide, you need to set this:
set sstv2_refresh_640x480=hz (I think you can use 60, 75, 85, 120)
Also, I found out that old 3dfx drivers (before 1999) don't work with cpu's faster than ~500 MHz. The games lock up.
