Reply 20 of 20, by lightmaster
lightmaster
Offline
- Oldbie
wrote:And I am in fact now using DOSBox-lfn. I've already found a use for mouse copy-paste, and automatic mounting is an obvious benefit as well. Though I now mount all my hard disk partitions in autoexec so I can use the same paths I'm used to typing (and not waste any time manually mounting or remembering what I have mounted where), that won't work for the floppy drive as it gives a fatal error with no disk in it (the wiki says that floppy drives are automatically mounted - they aren't).
As to how I could make the mistake, the fonts certainly aren't entirely different when fullscreen (NTVDM starts in 50-line mode, yes, but gets reset to 25-line (as DOSBox) when an application exits), which I was at the time and prefer.
Good Demiurg..
