Pentium 233 MMX to K6-2/300, worth it?
Reply 20 of 23, by Tetrium
Jade Falcon wrote:
Doable yes, but that last time I had a k6 setup I recall the FPS jumping around a good bit. A high end k6-iii+ setup will play it fine with the right parts and screen resolution. but a k62 will be pushing it.
Ftr, I was using a relatively low screen resolution. it does matter for fps, but err...I think Unreal is deserving of its name so I may be a bit biased here ^^
But seriously, fps wasn't having any real impact on my game performance.
Really gave me that post-movie-theatre feel when I finally managed to kill that queen 😁
My retro rigs (old topic)
Report spammers here!
Reply 21 of 23, by mrau
quite frankly - amd is faster than intel in ALU (business apps, maybe most parts of the system), intel is faster in FPU (a lot) - a 100 mhz increase will not allow the k6 to surpass the mmx; also 3dnow is not supported with amd k6, it starts with k6-2; if You want a k6-3 though you probably have to provide a much higher fsb rate (100mhz i believe); k6-3 is f*cking daemon compared to the other processors mentioned due to an added cache level(but fpu is still a bit weak);
amd cpus of this era always had trouble with high resolution, they slow down faster with increased reso than the intel chips;
why not OC the intel?
Reply 22 of 23, by appiah4
Im not sure my Voodoo 2 SLI setup will play ball with a faster PCI bus and my SDRAM memory is PC66.. and the MMX cant go over 3.5x so overclocking it isnt very attractive.
k6-3s are kind of expensive though the k6-2 is cheaply available.. I'll either get the 300 and OC or the 400 and see how much a boost I get..
