Reply 20 of 27, by BinaryDemon
Bummer thanks for testing. Its been my experience that Dosbox Distro detects the audio devices correctly on most atom chipsets that dont have hdmi out. 🙁
The N550 should be dual core with two way SMT for each core. It would make a nice MIDI emulator to pair with a real DOS machine.
wrote:Bummer thanks for testing. Its been my experience that Dosbox Distro detects the audio devices correctly on most atom chipsets that dont have hdmi out. 🙁
Can you guide me on how you do it? TinyCore or Debian? Tutorial?
I thinking of doing it on Debian/Ubuntu, since I am slightly much more familiar with apt-get.
I'm thinking of having DosBoxDistro, installed into the Harddrive's partition, dualboot from there.
Purely DosBox, for DOS gaming....
But again, I am not a Linux Guru. Can you help?
wrote:The N550 should be dual core with two way SMT for each core. It would make a nice MIDI emulator to pair with a real DOS machine.
Midi Emulator? Well, I do have a RealDOS machine.
I saw some phil's computer lab video, a Roland emulator, running on Windows.
Is there a Roland emulator, run on linux?
I looking for guide/tutorials in vogons... just need a real guide, coz I ain't no Guru yet.. 😀
@Panties, N550 is dual-core CPU with hyper-threading, so each physical core has 2 logical threads for the operating system. Therefore you see 4 cores in task manager.
A little about software engineering: https://byteaether.github.io/
wrote:@Panties, N550 is dual-core CPU with hyper-threading, so each physical core has 2 logical threads for the operating system. Therefore you see 4 cores in task manager.
Oh.. HT on each core, on 2 Local Core, so that's why it shows 4 Processors. 😊 Do you have any ideas on making this system, a useful one? (FYI, I just installed Archlinux last night.. I haven't install Dosbox on arch yet...) 🤣
wrote:wrote:@Panties, N550 is dual-core CPU with hyper-threading, so each physical core has 2 logical threads for the operating system. Therefore you see 4 cores in task manager.
I have a similar netbook, EEE PC 1015PEM. I have a tiny plan of making it to run my stock portfolio with software i have written myself, but that's it. (It can handle those few divisions and multiplications easily 😜)
A little, low-power machine with battery (almost like UPS) seems to be not too bad option for that.
I have windows 7 on it and just to try it out, i have dosbox installed with few games. It's fine for that.
wrote:Is there a Roland emulator, run on linux?
I run Munt and FluidSynth for this. It sounds like you can use Falcosoft Midi Player (FSMP) in Wine as well, although I haven't tried that.
