SBC 486 DX4-100
Reply 20 of 26, by vmswift
Used UNIFLASH to backup the bios. I didn't wanna remove the award bios label to figure out what chip I have for my programmer.
Bios Info: 07/18/96-ALI-1487/87-2A4KDP6GC-00
Also included is the Original Utility disk. I'm missing 2 files from the original disk due to bad sectors. Those files are only for WINNT and are listed in a file I created.
Use the included Utility Disk files(Drivers, Patches, or AWDFLASH) or bios backup at your own risk. I'm not responsible for what anyone does.
I will see if I can make time to scan that 80+ page manual next.
Reply 21 of 26, by Horun
Good info and thanks ! Could you post pictures of the complete inside of the computer ?
Only owned one older SBC because the back plane plus other parts just made it more of a hassle than an actual AT style board and took up as much room as a mini tower with baby AT.
Maybe I just did not have the right parts....but I saw no advantage. Thanks !
Reply 22 of 26, by vmswift
Horun wrote on 2021-10-24, 03:23:
Mine came in the original motherboard factory box which is why I have the manual and utility disk. I don't have a backplane or case for it yet. Maybe one of the others can help you with that.
Reply 24 of 26, by mt777
@vmswift
Thanks for dumping bios. It is a 6 days newer version than mine. Cyrix still doesn't boot with it, but I am happy that could setup properly Am5x86.
My bios with G6.
    G6.zip
    96.16 KiB
    42 downloads
    896.71 KiB
Reply 26 of 26, by DerBaum
Here is some more info:
I have 2 versions of this board.
One is a G7 (Am486DX4 100, gold cooler) Bios Date 07.18.96
One is a G9 (Am5x86-P75-S, black cooler) Bios Date 01.08.98
Both of them are labeled as PIA-410
1.83 MiB
1.99 MiB
1.27 MiB
1.36 MiB
I read both the Bios properly with my Eprom reader. I identified the chips as Macronix MX28F1000P from the ID my programmer read from the chips.
The attached ZIP contains both Bios files. Named MX28F1000P_G7.BIN and MX28F1000P_G9.BIN .
MX28F1000P_G7_G9_BIOS.zip
132.77 KiB
27 downloads
FCKGW-RHQQ2
