Reply 20 of 26, by ggms
wrote:Ok Guys, thanks for the feedback and thoughts. I think keywords are only useful for giving the possibility for restricting the n […]
I think keywords are only useful for giving the possibility for restricting the number of resos in a hardware-independent way.
For all other cases, one can edit the config file and type the resolutions for their current display hardware.So, to keep it all simple, I think 'max_4_3' and 'max_16_9' (meaning the max resolution for the given aspect ratio, based on the desktop resolution) could be enough.
Sorry for starting this again, I was busy so I had no time to make my own repack for this game testing newer version of dgVoodoo...now that I do, I'm still puzzled, maybe I'm missing something..
I STILL can't add default desktop resolution to ExtraEnumeratedResolutions by dgVoodoo alone automatically?
Let me explain...I have one monitor, 1920x1200 native resolution. Forsaken adds too much resolutions so I have to override it with combination of DefaultEnumeratedResolutions, ExtraEnumeratedResolutions or EnumeratedResolutionBitdepths. Thank you for that Dege. If I overlook EnumeratedResolutionBitdepths (yes, if I set only 32bit resolutions it will work but that not the point of my remark) and I use:
DefaultEnumeratedResolutions = classics
ExtraEnumeratedResolutions = max_16_9
I will get classic resolutions + 1920x1080.
max_16_10 does not exists (and it shouldn't in my opinion, it just complicates things...)...and  I have no 1920x1200, my native monitor (and desktop) resolution.
Ok, so I tried ExtraEnumeratedResolutions = max, even if max is not described as possible option, to my suprise it is taken into account but as 1600x1200 resolution (?)
My point is - there is still no way I could use dgVoodoo.conf alone to make my setup universal to work with on diferent graphic card/monitor combinations without coding special [INI] modification during install that will write current desktop resolution in ExtraEnumeratedResolutions into dgVoodoo.conf  😢 I did that, it's easy but it would be so simpler if I can finally write ExtraEnumeratedResolutions=whatever,whatever,max where max is my current desktop resolution. I see no way to do that with 2.55.2 version, my Inno setup must read my resolution (I'm using get_hw_caps.dll) and write it exact, like 1920x1200.
Did you overlooked this by mistake maybe, I really see no reason why dgVoodoo can't read current monitor resolution and use it as max in ExtraEnumeratedResolutions. Max keyword is ok, but currently for 1920x1200 monitor  it translates into 1600x1200, don't know why...  😢
Thanks,
regards
