Demo songs for Roland SC-88VL
Reply 20 of 24, by yawetaG
derSammler wrote on 2020-04-01, 18:21:
I'm not even sure if you can use more than 16 channels over the serial connection, as the data rate is not high enough for that...
Some serial MIDI drivers can send more than 16 channels over a serial connection if you enable specific options...
Reply 21 of 24, by derSammler
But that would require that the device supports it and also that the serial connection runs at twice the normal speed. Which device can handle that? I don't know of any.
The serial connection is normally just a MIDI In with RS-232 protocoll and an adapted baud rate. Even for devices with USB, you can't just send more than 16 channels. Instead, you get e.g. two virtual MIDI devices that can take 16 channels each. That's because MIDI is limited to 16 channels...
Reply 22 of 24, by yawetaG
derSammler wrote on 2020-04-03, 17:31:
AFAIK, that's exactly what those serial drivers will do.
Reply 23 of 24, by SuperDeadite
I use the serial on my mu2000, and it can handle all 64 channels at once in both directions.
CM-64, CM-500, SC-55MkII, SC-88 Pro, SY22, TG100, MU2000EX, PLG100-SG, PLG150-DR, PLG150-AN, SG01k, NS5R, GZ-50M, SN-U110-07, SN-U110-10, Pocket Studio 5, DreamBlaster S2, X2, McFly, E-Wave, QWave, CrystalBlaster C2, Yucatan FX, BeepBlaster, SuperOctet!
Reply 24 of 24, by Mudstep
DX7_EP wrote on 2018-04-21, 06:47:
Not all demo songs of the SC and SD modules are included in the devices' ROMs; most usually came with the driver disks or CDs.
Of course, the 88Pro MIDIs and many things designed for that module don't work properly on a 88, due to a bunch of missing instruments, effects, and parameters 😜
Anyways, I've uploaded the SC-88 (and as a bonus, the SC-55 and the GS All-Stars) demo MIDIs. Those for the 88Pro, 8820, 8850, SD-20, SD-90, and Virtual Sound Canvas are also available on request.
May you post the SD-20, SD-90 and SC88Pro midis?
