Reply 20 of 52, by feipoa
- l33t++
I found that with my S3 968 4 MB card that I had to use Synchronise, as opposed to transparent, for Windows 95 to run reliably, however, I think transparent was OK in DOS. I'd have to dig up my old post to be certain of this though. I am also using the Asus VL/I-486SV2GX4 rev 2.1, though I am running it with a 40 MHz FSB, Am5x86-160 MHz, L1: Write-back, and 1024K cache. The Mach64, VLB, on the other hand, will run with transparent on the exact same hardware and configuration.
