Graphic card memory speeds
Reply 20 of 24, by Putas
Cbb wrote:
Agreed but really cant get the arythmethics idea... 100Mhz => 10ns, 133MHz => 7ns ok, no problem 83MHz => 35ns, 33MHz => […]
386_junkie wrote:
You still are struggling to do basic math!? I thought I had taught you this over in another thread... frequency (MHz) = 1 / wave […]
The Serpent Rider wrote:
30-40ns memory is an overkill though, because it's nearly impossible to overclock this cards up to ~80mhz.
You still are struggling to do basic math!? I thought I had taught you this over in another thread... frequency (MHz) = 1 / wavelength (ns).
Please learn...
80MHz = 1/80MHz = 12.5 nano seconds
40MHz = 1/40MHz = 25 nano seconds
33MHz = 1/33MHz = 30 nano seconds
20MHz = 1/20MHz = 50 nano seconds
How many times does 12.5 go into 40?
or how about 25 into 40?
or 30 into 40?
... better yet, how many 40's, go into 40?
83MHz => 35ns, 33MHz => 70ns these values do not connect to previous line.
May be making conversion I have to take into account memory organisation (SDRAM/EDO/FPM)? Or it depends on some another things?
Just wanna put the things in order
Of course you have to, "great" math of 386_Junkie is for SDRAM convention only.
Reply 21 of 24, by The Serpent Rider
Better access time also doesn't equal better timings 100% of the time. And FPM/EDO memory is an unexplored rabbit hole in that regard.
Reply 23 of 24, by Montgomery
I'm sorry for being a bit off topic but I have some memory related problems with my 3Dfx Voodoo Rush (Macronix) card. It is the one with the framebuffer memory expendable by 4 sockets in the upper left corner, which is now populated with similar chips to the ones at the board itself (256k x 16, 35ns). The Video BIOS (at startup) however only reports 2MB frame buffer and 2MB texture memory as does the Macronix Win95 driver. The card works with or without the additional chips always reporting the mentioned values. Do you have experience or any ideas what might be a problem? BIOS, memory chips or the card itself? I would greatly appreciate any help! This is the card anyway 😀
243.53 KiB
Reply 24 of 24, by feipoa
I have witnessed such symptoms on other graphic cards and wish I an answer for you. Hopefully somebody else has some insight.
