Reply 20 of 20, by GhostyGhost
GhostyGhost
Offline
- Newbie
wrote:Did you check that both gpu's are actually functional in windows?
Sorry for not replying on time, I have determined that the Voodoo 5 5500 had a hardware problem and have since resolved it. It needed new VRAM chips and some capacitors to replace due to age and use.
Thank you for your inquiry though. I'll update the post.
If life throws a wrench into your plans, then show life that no matter what it does to you, you will always prevail.
