AWE64 Gold vs non Gold: What’s the deal?
Reply 20 of 37, by Anonymous Coward
dr_st wrote:
That card was some special OEM edition which was really an SB16, but due to some bizarre decisions shared the PCB and number of the AWE64. That card is completely useless for DOS gaming, since it cannot produce FM music at all.
Wait, it can't do FM at all? Isn't the CQM integrated into the main IC?
Reply 21 of 37, by 33oldnew
I checked my Gold CT4390 and Value CT4520.
I do not see an important difference in the quality of sound, noise and harmonics.
IMO:
If we use an external MIDI device, I do not see any important differences.
We have some good SoundFonts between 3 and 4 MB, in this case Gold is a good option.
I found other good SoundFonts in size 4 to 8 MB, and better in size 24 to 28 MB. In this case, we need SimmConn + memory, and choosing Value will be cheaper.
IMO: If we want a better Creative ISA card, let's look at AWE32 e.g. CT3980, but other problems.
Reply 22 of 37, by dr_st
My understanding from this discussion is that it cannot do FM in DOS, because you still need to run AWEUTIL /S to initialize the part responsible for FM/MIDI, and AWEUTIL won't run on this card. It is possible that I misunderstood, because it is not clear whether the card owner was referring to being unable to run AWEUTIL /EM (for MIDI emulation) or AWEUTIL /S (for FM/EMU8000 initialization).
You are right that CQM is integrated into the main chip, and FM should work without the wavetable samples. It will work in Windows. In DOS you still need to run AWEUTIL /S, unless someone figured a way to initialize the CQM portion in a different way.
Reply 23 of 37, by appiah4
Not being able to run AWEUTIL /S is pretty unlikely but from Creative not wholly unprobable; the card probably has something pretty fundamental neutered so that AWEUTIL may not be able to find any cards on the ISA Bus that it thinks is an AWE. It may have to do with the card reporting itself as a SB16 even.
Reply 24 of 37, by walterg74
So I have to mention, a disappointment I just had…
That AWE32 CT3670 that I thought I had gotten, it turns out it is the same model number but it is an SB32…
Reply 25 of 37, by appiah4
Aside from lacking Wavetable, IDE headers, onboard RAM and CSP it is the same card essentially; For Windows, lack of any of these will not be important, just slap on 2MBs of 30pin SIMM and load the 2MB Creative GMGS Soundfont for MIDI playback. As an AWE32 card, they have the exact same synthesizer.
Reply 26 of 37, by walterg74
So still worth it? What about FM? Read that it has a crappier one than the AWE. By the way, it does have the IDE header.
Reply 27 of 37, by appiah4
FM depends on the model; some SB32s have OPL3 some have CQM. Similarly, some AWE32s have OPL3 and some have CQM. Neither is automatically the better choice.
Reply 28 of 37, by realnc
IMO, OPL has to be the better choice, since CQM will sound different in some cases. Which one sounds better is subjective. IMO, OPL sounds better.
Reply 29 of 37, by appiah4
Define OPL. SB Pro's OPL sounds infinitely different from SB16's, which in turn sounds different from OPL on other cards like Sound Galaxy or PAS cards. And they ALL sound different from Adlib and Adlib Gold. They are all filtered differently and some even seem to run on different clock speeds. There is no ONE OPL3, and not all OPL3s sound 'better', in many instances Crystal FM sounds better to me than OPL3. ESFM sounds better than any other FM Synthesis to my ears. It really is subjective.
That said, I never meant CQM may be better than OPL3 (it is not, imo), I just stated that AWE32s have no guarantee of having OPL3 and SB32s are not all inferior models with CQM.
Reply 30 of 37, by dr_st
CT3670 is a SB32. It was never called "AWE32". It is in fact an AWE64 with 0KB RAM and SIMM slots (instead of the proprietary connectors). If you are looking for external sound fonts, it may actually be a better option than a "true" AWE64, because you just need standard SIMM modules to expand the RAM.
Being an AWE64, it uses the CT8903 chip which has the integrated CQM FM module. No AWE64-based card has true Yamaha OPL3. Even most AWE32 do not (but some do).
Reply 31 of 37, by walterg74
dr_st wrote:
CT3670 is a SB32. It was never called "AWE32". It is in fact an AWE64 with 0KB RAM and SIMM slots (instead of the proprietary co […]
I guess then this is just wikipedia screwing up the model numbers again,,,
Reply 32 of 37, by realnc
Hm, I wasn't aware of that. I was referring to comparisons like this:
https://www.youtube.com/watch?v=9hzxE1_nl0k
and this:
https://www.youtube.com/watch?v=rXWIx60FKS0
I thought the OPL just sounds deeper and with better bass. Is this due to different components around the used FM chip and not due to the chip itself?
Reply 33 of 37, by appiah4
I would argue that ESFM has better range and bass response in that second video but unfortunately it was recorded on a poorly filtered cheap card hence the floor noise.
Check this out for how different Genuine YaMaha OPL3 can sound on different cards with different filtering.
https://youtu.be/_ibdIm-ZBB4
Last card is a properly filtered ESS Audiodrive with great warm and punchy FM Synthesis, it sounds closer to the SB Pro than some of the SB16s with no bass response whatsoever IMO.
Also check out the Crystal FM. People diss Crystal for not being genuine OPL3 but can you honestly tell me it is worse? It is different but still very pleasant. That sweet drumset..
Long story short, OPL3 is not the holy grail of FM music. 😀
Reply 34 of 37, by buckeye
tayyare wrote:
^^ Completely agree with that. Besides, as it is already mentioned above, SIMMCONN will eliminate the RAM size difference, too.
But a "Gold" feels much cooler than a "Value" however 😊
Hey! here at Vogons it's all about our "feelings". I wish there was a clip somewhere of Chris Farley doing his "feelings" bit in Tommy Boy.
Intel SE440BX P3 450 256MB 80GB SSD Asus V7700 GF2 64mb SB 32pnp 350W 98SE
Reply 35 of 37, by tayyare
ahh, you are hurting my feelings...
GA-6VTXE PIII 1.4+512MB
Geforce4 Ti 4200 64MB
Diamond Monster 3D 12MB SLI
SB AWE64 PNP+32MB
Adaptec AHA29160
3com 3C905B-TX
Gotek+CF Reader
Reply 36 of 37, by The Serpent Rider
20% cooler.
Reply 37 of 37, by badmojo
But 200% more expensive 🤣
