Reply 20 of 24, by dparadise
I did a dir /p command first and you can see that there is a file called "SS2.EXE"
Then at the c prompt I typed "SS2.EXE" and the result was that it could not find the file ???
see attached
    103.23 KiB
Reply 21 of 24, by ripsaw8080
Rank DOSBox Author
DOSBox Author
Yes, NOW the SS2.EXE file is there, no doubt because you have subsequently replaced it.
See your earlier screenshot of a DIR command in DOSBox where SS2.EXE is NOT there: download/file.php?id=60129&mode=view
Now that the executable file is there you are no longer getting "Illegal command: SS2.", which is a DOSBox message, and instead are getting a "Filename not found" message from the game itself, presumably due to some OTHER file that is missing or can't be found.
You should just reinstall ALL game files, I guess from that SS2V3.ZIP archive visible in your latest screenshot. This is the last advice you will receive from me.
