Reply 20 of 29, by appiah4
- l33t++
I'm also keen on the Octek HIPPO-VL+, it's indeed an interesting board. It has no cache, but I don't know how much DCA helps with that, or whether the 8MB 30-pin RAM that came on it is actual EDRAM or just regular FPM. It would be interesting to test.
The board's chipset is Headland HT340 and it apparently has a MR. BIOS chip on it. It came my possession in a somewhat poor condition: the chipset had some bent legs and one leg that had separated from the motherboard completely, I realigned and soldered that back on. It also had a battery leakage I cleaned with alcohol and neutralized with vinegar as I best could. I have not tested it after these fixes though.
It is an interesting board for sure, and has no VRM for 3.3V CPUs, so that limits my choices processor-wise; but I am not starved for choices either way, with a few Overdrive CPUs and several SX/DX CPUs to choose from. I don't mind LIF sockets, they are fine as long as you are careful. The U5SX and Octek do sound like they could be a fun (or terrible) pairing indeed.
The other board I am similarly interested in this bunch is the DataExpert EXP-8046. It has ISA, VLB and PCI all in one place, can accept 3.3V CPUs, is ZIF, has onboard IDE/FDD controller, full cache and 72-pin SIMM slots - it's a decent transitional board from the VLB era to the PCI. I don't know about the UMC chipset, however; UMC chipsets I've come across from the era mostly focus on being more affordable. A fast 486 is not what I am going for here, though, unless someone sways my mind..
