Restoring an AMD 386 system, need some advice
Reply 20 of 36, by VioletGiraffe
On an unrelated note, would it be possible to use an IDE DVD-ROM drive for reading CDs (not DVDs, of course) on this machine?
Reply 21 of 36, by Warlord
should work, can't guarantee that the drive you want to use will be compatible, thats not to say that a normal cd/dvd combo drive wouldn't work. try it assuming you have one just laying around. if you are buying one, id recommend to get older used drive, or new old stock and not buy new drives. Sombody else recently made a thread about some newer drive they had and didn't have a CD header. 🤣 I had the best luck with LG drives.
Reply 22 of 36, by VioletGiraffe
Thanks! I have a bunch of Asus and one LG multi DVD recorder drives, all of them IDE, that's why I'm asking whether it makes sense to try one or if it's a lost cause. Will give it a try and see how it goes!
Two of the drives even support Lightscribe - a technology I didn't get a chance to try back in the day, but would be excited to give it a try now (not in a 386 computer, naturally).
Reply 23 of 36, by maxtherabbit
it was even dumber than that -it did have a CD header that didn't output anything by design 😵
Reply 24 of 36, by VioletGiraffe
I noticed that one of my drives has a CD header but it's labeled "Reserved". All the other drives properly list it as "CD Audio".
Is this header needed for anything other than listening to CD-Audio discs? I don't imagine any games need it?..
Reply 25 of 36, by maxtherabbit
right except some games stream CD-audio as their music
Reply 26 of 36, by VioletGiraffe
Need some help with the turbo button connector. Photos:
https://i.imgur.com/QuFDBZB.jpg
https://i.imgur.com/VlLp6Hw.jpg
As you can see, the case has a single connector for switch and led, and the motherboard has them separately. Do I just use a dupont wire to route this? And where is the positive and negative on the motherboard? Which side is marked with "1"?
Also, what is this jumper monstrosity on the turbo display board? Is it used for configuring the turbo and base clock values?
https://i.imgur.com/zdIDlyw.jpg
Reply 27 of 36, by FAMICOMASTER
The jumper monstrosity on the turbo display is probably around here somewhere:
http://www.minuszerodegrees.net/led_speed_dis … eed_display.htm
It sets the *displayed* frequencies when you push the turbo button.
Reply 28 of 36, by VioletGiraffe
So my turbo LED board is TD-38S, and I can't find a schematic for it. I don't need to reconfigure the jumpers as they should already be set to the right thing, but I don't understand how to connect its 3-pin header to the motherboard's 2 + 2 headers ("turbo switch" and "turbo LED", depicted in my post above).
Reply 29 of 36, by GigAHerZ
Just connect center and one of the side pins of turbo switch to motherboard. The switch either connects left and center or right and center. Depending on which way you insert this 3pin wire to 2pin headers, the turbo has to be pushed in or out to be in turbo state.
Just try and set it as you like.
With MHz display, i've just taken it out, provided 5V power separately and played around with jumpers. Eventually you start to understand the pattern so with the second digit, it already goes fast for you. 😀
A little about software engineering: https://byteaether.github.io/
Reply 30 of 36, by TheMobRules
Here's how the turbo switch + LED display should be connected:
  1. The turbo button in the case normally has 2 sets of 3 wires coming out of it, one of them (probably the one labelled "TURBO SW" from your picture) is connected to the "TUB SW" header on your motherboard and is used to actually make the board change its speed when you press the button. You have a 2 pin header, so just plug the connector in any orientation so that the wires in the middle and one of the edges are connected to the header.
  2. The other set of 3 wires needs to be connected to the LED display, you need to identify the pins where you want to plug it in, normally they are labelled "L", "C" and "H". Again, the order does not matter, the middle wire will always be connected to "C".
  3. The "TUB LED" header is for connecting the little yellow/orange LED that turns on or off depending on the state of the turbo button. It's just like the power or HDD LEDs, though in some cases this LED can also be connected directly to the LED display, which may be your case.
Reply 31 of 36, by FAMICOMASTER
There are different types of LED speed displays. They can be driven directly by the switch and pass it to the motherboard, or they can be driven by the motherboard's LED output.
Reply 32 of 36, by VioletGiraffe
Achievement unlocked, thanks for the tips!!!
Now the only thing I can't get to work is the HDD LED. It was plugged into the IDE expansion card when I got the computer, but it doesn't light up. There's a row of like 15 jumpers on the card, most of them closed, some open, and the LED was plugged into J1. There is no place that says "HDD LED". I tried reversing the polarity of the diode in J1, also tested the diode and it does work. Puzzling. Of course, the card lacks any markings.
Reply 33 of 36, by GigAHerZ
Give us a hi-res photo of that io card, we'll see, what we get out of it. 😉
Reply 34 of 36, by VioletGiraffe
So I accidentally got it right while fiddling with the board, now everything works!
Apparently, all you need is to ask the right people 😀
Now onto writing software for this beast, very excited!
Reply 35 of 36, by FAMICOMASTER
Try TH99. They have a lot of jumper settings and connection points for all kinds of those cards.
http://th99.infania.net
Reply 36 of 36, by VioletGiraffe
Wow, nice resource, thanks a lot!
