Reply 20 of 22, by cyclone3d
I didn't use anything other than that package I posted.
Did you copy all the files to a floppy disk in drive a: run the install.bat from drive a: ?
I ran it from a DOS command prompt (didn't boot into Win98SE)
It should have copied all the files to:
C:\OPTI931
It should have put these at the beginning of your autoexec.bat file
SET BLASTER=A220 I5 D1 T4
SET SOUND16=C:\OPTi931
And these at the end of your autoexec.bat:
PATH C:\OPTi931;%path%
C:\OPTi931\SNDINIT /b
It would have also put a line at the beginning of your config.sys file for a CD-ROM driver which you don't need.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 21 of 22, by VioletGiraffe
Oh wow, reading was not a skill I practiced yesterday, apparently. First, I missed the bit about having to run install.bat! And second, I set the jumpers on the card backwards: I assumed pins are numbered left to right and top to bottom, but it was the exact opposite. Once I ran your script AND enabled PnP with the jumper, it works!!!!
Now I can enjoy Monkey Island's iconic music coming out of period-correct Braun L880 speakers through a more or less period-correct Telefunken HA880 amp 😀
BattleTech: The Crescent Hawk's Revenge also works!
Tomorrow I'll uncork a bottle of Australian wine and toast for you!
