Reply 20 of 30, by jheronimus
Add Intel VS440FX (Venus): Socket 8 ATX with 4 ISA slots.
As to Slot 1, I would look at very early 440FX-based motherboards since I don't think I've ever seen a 440BX or 440LX with 4 ISA slots. Supermicro P6SKE/P6SKS is a good example.
MR BIOS catalog
Unicore catalog
Reply 21 of 30, by brownk
VS440FX was listed from the get-go.
Appreciate your input. I'll look out for it.
Reply 22 of 30, by iulianv
brownk wrote:
iulianv wrote:
Biostar MB-8600TTX-A (socket 8, Intel 440FX)
Спасибо!
The Biostar I have, the Chaintech 6ITM I googled, but you can quickly expand your list by scanning for ATX boards with 4 ISA slots through the TH99 listings - for example, there are two pages dedicated to Slot1 mainboards here - https://stason.org/TULARC/pc/motherboards/index.html - where I learned about ATC-6100 R1, DFI 686IPK, EPOX KP6-FX, LUCKY STAR 6IX-1 and 6IX-LXI, MSI MS-6109 and MS-6112, TYAN S1684SA, SUPER MICRO P6SKE and P6SKS as already mentioned here, and some other brands I hadn't even heared about...
Reply 23 of 30, by Windows9566
ATX with 4 or more ISA
ECS P5HX-A - 430HX
ECS P5VX-A - 430VX
AOPEN AX5T - 430TX
FIC PA-2010 - VIA VP3
DFI 586ITOX - 430TX
DFI 586ITXD - 430TX
R5 5600X, 32 GB RAM, RTX 3060 TI, Win11
P3 600, 256 MB RAM, nVidia Riva TNT2 M64, SB Vibra 16S, Win98
PMMX 200, 128 MB RAM, S3 Virge DX, Yamaha YMF719, Win95
486DX2 66, 32 MB RAM, Trident TGUI9440, ESS ES688F, DOS
Reply 24 of 30, by xjas
Spotted this on "the big auction site." FIC PA-2011:
433.65 KiB
Reply 25 of 30, by brownk
Greatly appreciate them. (I could not add some of them as there aren't many links I can look into.)
Windows9566 wrote:
ATX with 4 or more ISA ECS P5HX-A - 430HX ECS P5VX-A - 430VX AOPEN AX5T - 430TX FIC PA-2010 - VIA VP3 DFI 586ITOX - 430TX DFI 5 […]
ECS P5HX-A - 430HX
ECS P5VX-A - 430VX
AOPEN AX5T - 430TX
DFI 586ITOX - 430TX
DFI 586ITXD - 430TX
Thanks a ton! Added them all!
Thank you!
Soltek & 3 additional Supermicro boards were also added.
TIL Supermicro P6SKE & P6SKS can take S8 or Slot1.
Plus, there are bunch of Slot1 mobos w/ 4xISA.
WoW. Just wOw.
Reply 26 of 30, by The Serpent Rider
I'll look for CLR PC model numbers.
Ok, I did my own research and apparently this board came from that CompuLink Research line of computers.
"CLR Entrada" model no. PT5-E AX
MSI MS-5148 ver 1.1
Reply 27 of 30, by brownk
The Serpent Rider wrote:
Ok, I did my own research and apparently this board came from that CompuLink Research line of computers. […]
MSI MS-5148 ver 1.1
Señor, Gracias, de verdad.
Sincerely appreciate your time.
Reply 28 of 30, by rmay635703
appiah4 wrote:
OP asked for ATX boards and everyone is sharing AT boards, what did I miss?
My AT board also has an ATX connector and is currently in an ATX case with an AT case cover.
Reply 29 of 30, by appiah4
Its still not an ATX motherboard.
Reply 30 of 30, by evasive
Socket 7 (80): https://www.ultimateretro.net/en/motherboards … 5D%5Bcount%5D=4
Socket 8 (39): https://www.ultimateretro.net/en/motherboards … 5D%5Bcount%5D=4
Slot 1 (30): https://www.ultimateretro.net/en/motherboards … 5D%5Bcount%5D=4
As you can see, we now have a pretty powerful tool to answer questions like these
